no spark to the dizzy???
i have a 94 dx coupe with a d16z6 and im not gettin spark to the dizzy im throwin a code 15 for the ignition output signal chanded the dizzy still doin it wat could it be??? help me
spark=power=check fuze=check batt volt after trying to start it drains after awhile
then check the spark from plugs
always take the coil out and have the azone check it before you buy a new dizzy
also take the icm out and have it checked
often its a ground or the coil
the icm and the coil are often the problem if its not the ground or a run-down battery
check my post on this because its well covered
also look up the spark at the plug test
look up garage ninga/ninja
hope it helps
hope it helps
IWearMyKswiss
Sep 17, 2004 09:49 PM
