b18b into EG
Old Mar 9, 2011 | 07:59 PM
berretta96's Avatar
Default b18b into EG
SORRY FOR THE NOOB post
I've searched but haven't been able to find a guide for the swap, only a bunch of questions and drivability problems after swap.
I have a 95 DX and want to install a b18b and gsr tranny. Please point me in the right direction.
Thank you in advanace
Old Mar 9, 2011 | 08:12 PM
eghatch9295's Avatar
Stancetard Hate Monger
Default Re: b18b into EG
integra mounts, axles and linkage. whatever obd-1 ecu you want, your dx ecu will run it ok until you can afford something better. search stickys/faq threads, this has literally been covered in great detail thousands of times. the real question is is your b18b obd-1 or 2?
Old Mar 9, 2011 | 08:30 PM
SOHCCody's Avatar
Yea what he said, it is fairly simple, only problem s obd1 or 2. youl need a jumper harness if its 2.
Old Mar 10, 2011 | 04:41 AM
berretta96's Avatar
already have the harness and the engine, how would I identify which it is, obd1 or obd2?
Old Mar 10, 2011 | 05:03 AM
ferioLSv's Avatar
obd1 distrubutor has 2 smaller connectors on it and obd2 has 1 larger one..... if its out of a 96 or up its obd2
Old Mar 10, 2011 | 06:25 AM
tlarimer's Avatar
Here you go,
https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/dans-massive-obd2-b18b1-into-1992-civic-cx-hatch-write-up-2239971/
Old Mar 10, 2011 | 06:35 PM
berretta96's Avatar
^ EXACTLY what I needed. THANKYOU
AdrenalineAngel
Oct 27, 2012 08:25 PM
'92 HatchGuy
Feb 20, 2007 03:18 PM
dgmorr
17
Sep 1, 2005 09:20 AM
gildo86
Apr 29, 2004 06:47 AM
