Suspension & Brakes Theory, alignment, spring rates....
GC mounts for the rear?
Old Mar 9, 2011 | 05:14 PM
carracr625's Avatar
Default GC mounts for the rear?
I am building a 91 civic hatch for auto-x & an occasional HPDE. I am planning on using the ground control on koni set up. I have read about the benefits of using their upper mounts on the front to extend shock travel. However I haven't heard of anyone using them on the rear as well. Has anyone had any experience using them on the rear? Are the advantages similar to those on the front? Are they really necessary?
Old Mar 11, 2011 | 10:36 AM
rick_rabies's Avatar
I'm not Rick!
Default Re: GC mounts for the rear?
pm notajdmfanboy he has them
Old Mar 11, 2011 | 11:58 AM
TunerN00b's Avatar
The "advantage" is the same, additional shock compression travel.
However, the rear suspension of Civics and Integras have more travel than the front to begin with, and most people won't benefit from extending the rear mounts other than a reduction in droop travel (if that actually is a benefit).
Old Mar 11, 2011 | 09:09 PM
Tyson's Avatar
its useful in the rear to limit droop. it will go 3 wheeling around the turn easier, but thats not necessarily a bad thing...
Old Mar 17, 2011 | 10:35 AM
carracr625's Avatar
I appreciate the input fellas. I guess I'll try the set up with out them, and use the extra $ on other much needed parts. I can alway add them down the road.
Old Mar 21, 2011 | 09:05 AM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
If your springs are stiff enough, you won't need them. I used to roll on 380 lb front springs on Koni/GC, lowered a pretty good bit (top of tire even with fender) and never had any problems with OEM upper shock mounts.
Gregmatic
Oct 10, 2022 11:44 PM
sh0rt1e67
Suspension & Brakes
Mar 16, 2009 04:04 PM
Takumi Fujiwara
May 20, 2005 02:51 AM
AussieK24
Aug 20, 2002 12:31 PM
