prop valve??????please help!
Old Mar 9, 2011 | 04:55 PM
jdm inc's Avatar
Default prop valve??????please help!
I have a 93 civic eg hatch with rear disc brakes non abs. my stock prop valve went bad so i replaced it with a 40/40 prop valve the stock one was a 40/30 or 30/40. i Was wondering do i need the integra master cylinder to go with the 40/40 valve? Thank you.
Old Mar 9, 2011 | 05:21 PM
DCFIVER's Avatar
Community Builder
Loved
Community Favorite
Default Re: prop valve??????please help!
I would ,just for size alone. Bigger master=more pressure=better stopping
Old Mar 9, 2011 | 05:40 PM
jdm inc's Avatar
Thank you.
anyone else have any more info. Will the stock on i have be ok or is it not just enough pressure.
Old Mar 10, 2011 | 06:13 AM
jdm inc's Avatar
anyone else?
Old Mar 10, 2011 | 10:52 AM
DCFIVER's Avatar
Community Builder
Loved
Community Favorite
anyone else?
It will be enough to properly operate either prop valve you are using. The prop valve it self only changes the distribution of force between front and rear, it does not change the pressure required.
Old Mar 10, 2011 | 11:54 AM
jdm inc's Avatar
Ok thank you sir!
Old Mar 11, 2011 | 07:09 AM
94EG8's Avatar
Seagull Management
If you have small front brakes then all swapping a bigger MC is going to do is give you a hard pedal.
Old Mar 11, 2011 | 09:46 PM
jdm inc's Avatar
i have integra front brakes for my dss 5.9 axles.
Old Mar 12, 2011 | 04:26 AM
94EG8's Avatar
Seagull Management
Then you run a '94 - '97 Non ABS Integra MC (you'll need the matching brake booster as well) Or use a '90 - '91 Civic EX MC
Btw the stock civic hubs and the integra hubs have the same spline count where the axles go through so if that's the only reason you upgraded your brakes it really wasn't necessary.
Old Mar 13, 2011 | 10:53 AM
jdm inc's Avatar
the 5,9s required the larger bearing. cause when u get the axles they send u the hub with no wheel bearings and they required the integra or civic with abs hubs. so the wheel bearing will fit.
Old Mar 13, 2011 | 01:27 PM
DCFIVER's Avatar
Community Builder
Loved
Community Favorite
Why?
Old Mar 13, 2011 | 03:29 PM
94EG8's Avatar
Seagull Management
Originally Posted by DCFIVER
Why?
I don't know the theory behind it, but it does and that's really all that matters.
Old Mar 13, 2011 | 03:43 PM
night's Avatar
Why?
Look up how hydraulics work. It will move the same amount of fluid in a shorter stroke with the same size caliper piston.
Old Mar 13, 2011 | 09:26 PM
jdm inc's Avatar
i bled it twice and it just feels like it takes more push on the pedal for it to stop.
crower
Nov 15, 2015 05:59 PM
jetspeedz
Dec 20, 2011 10:00 PM
jdm inc
26
Mar 16, 2011 03:12 PM
sik_sol
Oct 25, 2006 04:23 AM
chronic
Sep 24, 2002 07:58 AM
