prop valve?
I have a 93 civic eg hatch with rear disc brakes non abs. my stock prop valve went bad so i replaced it with a 40/40 prop valve the stock one was a 40/30 or 30/40. i Was wondering do i need the integra master cylinder to go with the 40/40 valve? Thank you.
Taking a look behind my firewall it looks like the civic DX hatch doesn't have a 4040 prop valve, unless I can't find it. I've seen varying statements about the prop valve in my car. And part numbers even match:
46210-S04-952 VALVE ASSY., PROPORTIONING 1998 INTEGRA RS
46210-S04-902 VALVE ASSY., PROPORTIONING 2000 CIVIC CX Hatch
46210-S04-902 VALVE ASSY., PROPORTIONING 2000 CIVIC DX Hatch
46210-S04-902 VALVE ASSY., PROPORTIONING 2000 CIVIC DX Coupe
46210-S04-902 VALVE ASSY., PROPORTIONING 2000 CIVIC HX Coupe
46210-S04-902 VALVE ASSY., PROPORTIONING 2000 CIVIC SI Coupe
46210-S04-912 VALVE ASSY., PROPORTIONING 2000 CIVIC DX Sedan
46210-S04-912 VALVE ASSY., PROPORTIONING 2000 CIVIC DX-V Sedan
46210-S04-912 VALVE ASSY., PROPORTIONING 2000 CIVIC LX Sedan
46210-S04-922 VALVE ASSY., PROPORTIONING 2000 CIVIC GX Sedan
46210-S04-962 VALVE ASSY., PROPORTIONING 2000 CIVIC EX Coupe
I have a 4040 prop valve I ordered, and I don't see anything like it under my hood.
yea there are several others that use the 3040, but I dont have access to many junkyards, unless I want to drive 2 hours to el paso, which I suppose isnt out of the question.
Those part numbers are all for '96 - '00 Civics, and '98 Integra. '92 - '95 Civics are different. Basically '92 - '95 Civics and '90 - '97 Integras all share prop valves that look externally identical. '96 - '00 Civics and '98 - '01 Integras share prop valves that look externally identical. These two different styles are completely different and aren't interchangeable unless you feel like bending and flaring a bunch of lines.
Which one did you order? You didn't get the EG/DC kind, did you?
Or did EX/si civics with rear discs use a 4030?
The CX, DX, and HX use a smaller front disc than the EX/Sis of 96-00, I believe. The EX has the larger front discs of the Si but drums in the rear. So that is why I think they use a different prop valve. If you upgrade to Si front and rear disc brakes, and you have a CX, DX or HX model, you don't have to swap prop valves.
I have got no clue why Honda did it this way.But they did.
You have the same as a 99-00 SI.
The EX has 10.3''F and drum rear.
Si is 10.3''F and 9.6''R? I think this is correct.
