car wont start
Old Mar 9, 2011 | 03:32 PM
slowwcivic's Avatar
Default car wont start
car gets air fuel and spark it is in time but it sounds like its out of time tried putting the distributor in 180 out and it wont sit in right its an ls head and an ls distributor dont know whats wrong
Old Mar 10, 2011 | 08:12 AM
rick_rabies's Avatar
I'm not Rick!
Default Re: car wont start
ecu fuse?
main relay good?
firing order correct?
gas in the tank?
Old Mar 11, 2011 | 12:30 AM
truckboy's Avatar
Kindly check the battery terminal connection, it they are corroded, it is needs to be replaced, if you are getting clinking noise then it means that battery is dead, check inside the distributor cap,if moisture is there then kindly clean the same. kindly check air filter, carburetor, spark plugs and the timing.
___________________________________
Motorcycles For Sale | Scooters For Sale
Old Mar 11, 2011 | 06:04 AM
fcm's Avatar
fcm
Old Fart
Need more info...
MM&Y of car?
What do you mean it will not start, will not fire or will not even crank, [turn over]?
Have you checked valve timing? 94
Old Mar 15, 2011 | 02:33 PM
slowwcivic's Avatar
figured it out it was a junk dizzy
dirrtybirdy
Mar 28, 2010 01:43 PM
builtboostedteg
Jun 13, 2006 03:04 PM
turboblkek
Sep 7, 2005 04:05 PM
b18c-93
Jan 24, 2002 08:28 PM
