Transmission & Drivetrain Gearboxes, Differentials, Clutches
Driving different stages of clutch?
Old Mar 9, 2011 | 02:02 PM
Raf99's Avatar
Default Driving different stages of clutch?
Sorry for the newb Q, easy-one for someone. In regards to clutches and the daily operations, how does a normal clutch compare to a Stage 4 clutch?
- does the clutch still catch in the same spot (pedal position)
- is there less or more play ("riding the clutch")?
- is it less forgiving and how so?
Another angle to the Q would be, do you drive the same with a OEM clutch compared to a stage 4 clutch?
thanks in advance
Old Mar 9, 2011 | 02:08 PM
95streetciv's Avatar
Default Re: Driving different stages of clutch?
I drive similar with my stage 3, 6 puck clutch as I did with OEM. It is a sprung clutch, and it still will slip a little if you "ride it".
Less forgiving ya sure, if you pop it too hard, you might break something.
Couldn't say about your stage 4. the brands are all different too, as far as stages go.
Old Mar 9, 2011 | 02:57 PM
Raf99's Avatar
Especially breaking in a new stage 4 clutch for the first 1K, should there be any change of clutch use compared to an OEM?
It sounds like they re-act the same, but this one will have some more bite to it.
Old Mar 9, 2011 | 03:04 PM
Gearspeed-Performance's Avatar
Different clutch makers will have different stages at different rates. Some will give you a heavier pedal and require more pressure to engage clutch at "x" stage..depending on vehicle as well. Others will vary with sprung and unsprung hubs and the engagement can be mild to harsh with no forgiveness. Just depends on what clutch you buy. Do some searching around and some research on here and compare peoples perspectives on different clutches.
Old Mar 9, 2011 | 05:10 PM
Raf99's Avatar
Its a Bully stage 4 sprung. After reading your post did some reading for the past 30 min here. Great reviews. Not much of a difference in pedal weight, same engagement point, but more solid engagement.
thanks for the help
Honda-ls-hatch
Feb 2, 2011 01:50 PM
slowj
Jan 18, 2004 06:25 AM
shotty527
Nov 2, 2003 09:00 PM
Que_Lude
Oct 27, 2003 06:52 PM
