Can I use OBD1 injectors with an OBD2 engine?
Old Mar 9, 2011 | 01:09 PM
BryanM.'s Avatar
Resident Gearhead
Default Can I use OBD1 injectors with an OBD2 engine?
Car is a '96 DX. I want to replace the D16Y7 injectors with D15B8 injectors. The Y7 injectors have been used for ~200k miles. To reduce down time, I want to send the B8 injectors away to be cleaned and balanced, and then I will swap out the old Y7 injectors with the clean B8 injectors.
What I think I know:
(Please correct me if I am wrong or tell me if I am right)
◕ Both the Y7 and the B8 use 180 cc/min injectors
◕ Both are peak and hold
◕ Connectors are different
I have a set of OBD1 injector connectors. Is there any reason I can't use them with my OBD2 harness (cut the OBD2 connectors, splice in the OBD1 connectors)?
Will the B8 injectors fit correctly (in the rail, in the manifold, too long/too short etc.)?
Anything else that I haven't covered that may be an issue?
If all this seams fine, please say so. Thanks guys!
Old Mar 9, 2011 | 01:54 PM
94EG8's Avatar
Seagull Management
Default Re: Can I use OBD1 injectors with an OBD2 engine?
Should be fine, they're electrically the same, as long as the fitment is the same (which i'm about 99% sure it is) then you wont have any problems.
Old Mar 9, 2011 | 03:12 PM
slowwcivic's Avatar
they work the same but im pretty sure the plugs are different
Old Mar 10, 2011 | 02:31 AM
BryanM.'s Avatar
Resident Gearhead
That is what I am most concerned about. I would hate to tear everything apart just to measure/compare the injectors.
I'm pretty sure they are the same as well.
thaiphob
Aug 4, 2017 10:40 AM
sageuvagony
Sep 22, 2008 12:47 AM
.BigSexy
Mar 21, 2008 02:39 PM
ekb18cCivic
Nov 15, 2003 05:12 PM
94cxHybrid
Aug 29, 2001 11:27 AM
