Hondata s300/Boost option/USB port $600 shipped
Up for sale is my Hondata s300 ECU setup. It is installed inside of a P72 that was virgin. Works flawlessly. Has the data port installed along with the cable. Plug and play tunability. Selling for $600 shipped. (ECU along with Data Cable) no negotiations. Not in a rush to sell. Pictures upon request (Nothing to see really..they all look the same. Has a Hondata sticker on top of the ecu) FREE SHPPING
Boost option is for boost by gear.
This same set up sells for $590 on evans-tuning if you have your own ecu already, which also comes with a 50-100 dollar coupon.
Is the P72 the correct ECU for a 98 Civic? I thought I needed a P28? I could be mixing up numbers. If this will work for my car I'm interested.
you will need a OBD1 ECU... p72, p28 whatever it is that is CHIPABLE...you will need to get the conversion harness .... OBD2A to OBD1 to run that ecu
Correct, his S300 comes with a P72 already. I was trying to see if that's the correct ECU for a 98 Civic which is D16Y8 VTEC. I *think* the correct ECU I need is the P28. I was looking on phearable.net and they make it seem like I need the P28. If that's true then I should probably pass on this deal.
But the b18 is a DOHC motor. Does that not matter? Are you saying I can use either the P72 or the P28 in my car with the ODB2A to ODB1 harness and have no differences or side affects?
