Transmission & Drivetrain Gearboxes, Differentials, Clutches
Replacing clutch and flywheel. Any advice?
Old Mar 9, 2011 | 07:42 AM
97CivEx's Avatar
Default Replacing clutch and flywheel. Any advice?
I am replacing the clutch and flywheel on my 97 civic. I have access to a lift and all the tools I'm gonna need, but I will be doing it myself. what would be the easiest way to do it? should I drop the engine and transmission out the bottom, or just the transmission? Any suggestions would be welcome.
Old Mar 9, 2011 | 10:27 AM
Gearspeed-Performance's Avatar
Default Re: Replacing clutch and flywheel. Any advice?
I always just pull the trans...Pulling the whole engine and transmission is more work and not necessary for swapping clutch and flywheel. Good luck!
Old Mar 14, 2011 | 07:19 PM
FlewByU352's Avatar
The best investment I made while doing a new clutch and flywheel was an air compressor/air tools and a transmission jack. A transmission jack makes life so simple because it holds the trans where it can't fall and it has so many different adjustments and pivot points to get it just perfect for lining up.
B_Swapped93
Apr 4, 2013 06:30 PM
MurphDog74
Jul 24, 2002 08:31 PM
JohnR265
Oct 12, 2001 04:16 PM
