b16 exhaust mani question
ok..i have a b16..but i dont have the lower piece of the exhaust manifold (b pipe?) what integra or civic does this come off of? please list all that will work..and will they mate up to my stock crx exhaust?
if i ran a complete usdm exhaust manifold i wouldnt be able to run 2 o2 sensors...does it run ok when you plug 2 wires into 1 sensor?
the point of the 2 o2 sensors was to get good readings from the cylinders (I think it pairs 1+4 and 2+3). You would think splicing one sensor that is taking readings from all 4 (like a usdm dc) would be ok. People have said to try and use both sensors. I personally am only running one. Motor runs ok, but a little rich I think (bad gas mileage).
will it mate with the factory exhaust?
mine didn't. i tried unbolting the cat and rotating it so it would bolt up. it was still about 2 inches too short..i stretched it and it bolted up. two weeks later i had a custom exhaust built..much better. about the 2 o2s..i was using the stock manifold, and had them hooked up backwards..i got a wierd hesitation at low throttle. once corrected it was fine. my advice...if you only have one o2, get a second bung welded in, and two o2s installed in stock locations.
bigblueandyellow
Jul 13, 2005 07:13 AM
curiousgpnoy
Feb 19, 2003 09:13 PM
555R
Jan 11, 2002 07:01 PM
