???????? Out law rule book ???????????
Old Mar 9, 2011 | 03:07 AM
zakura R's Avatar
Default ???????? Out law rule book ???????????
What up guys I want to know if there is any rule in the out law for having the air to water and ice box inside the car I see miller and T1 that have it on the front of the car and some guys on the engine compartment ??
Old Mar 9, 2011 | 03:49 AM
tony1's Avatar
Default Re: ???????? Out law rule book ???????????
Inside the car is fine.
Old Mar 9, 2011 | 03:51 AM
zakura R's Avatar
Thanks for ur info Tony
Old Mar 9, 2011 | 07:50 AM
CNC HMA's Avatar
Here is what I received from Roger.
OUTLAW STREET-designed for full bodied, street legal 4 cyl. fwd cars.
Minimum weights
2450 lbs for all cars. No penalty for nitrous.
Class Requirements
1.Engine
ENGINE:
Engine swaps (e.g.,B series with B series) permitted; however OEM mounting points must be utilized. Engine swap (e.g., B series to a K series) permitted provided engine swap kits are commercially available and approved in advance. Engine must be from same manufacturer as body. Engine must be overhead cam, production based design. Maximum 2 power adders. Redundant power adders such as a dual stage nitrous system , will be counted as one power adder. Engine must be in stock, transverse configuration. Dry sump oil system or external oil pumps prohibited unless OEM equipped and engine is using complete OEM oiling system. External electric water pumps are allowed.
ENGINE CONTAINMENT DEVICE:
Engine diaper or catch pan device to capture oil and debris in event of engine failure mandatory. Where exhaust header passes directly under oil pan, two piece diaper may be utilized. FWD vehicles using OEM manual transmission case must also have such a device for the transmission, to capture oil and debris in event of transmission failure. if catch pan device is used, catch pan must employ minimum of 2 inch high lips on all sides. Lips must be coved or curved inward, so as to contain oil in pan. Catch pan must cover entire area below engine/transmission. Catch pan must extend from radiator support to firewall and from framerail to framerail. In all cases, lips must be adequate enough to contain oil in the catch pan. Should a competitor spill excessive oil from the catch pan and debris onto the track, he or she may be disqualified from further competition at the sole and absolute discretion of the event director until catch pan is upgraded, regardless of height of pan lips or pan design.
EXHAUST:
Optional.
FUEL:
Any race gasoline (E85, Q16, VP import, ETC.) permitted. Fuel Cell allowed - 2.5 gallon minimum. Must be in either stock location or in a sealed area behind the driver. Methanol is not allowed. All competitors will be checked at least once and are subject to random inspection.
TURBOCHARGER:
Restricted to a single turbocharger. Turbocharger must utilize a turbine housing inlet flange commonly referred to as the T04. Limited to a maximum 72mm turbo, where the maximum compressor housing inducer diameter is 72.78mm, measured at the point where the leading edge of the compressor wheel meets the housing.
Air to water intercoolers are permitted. CO2 or NOS is permitted as a cooling medium in place of water in liquid intercooler, but will count as a second power adder;i.e. is CO2 or NOS is used as an intercooler medium, NOS may NOT be used in the engine.
2.Drivetrain
FLYWHEEL SHIELD:
All cars using a clutch and running quicker than 11.49 or faster than 135mph must be equipped with a flywheel shield made of 1/4 inch minimum thickness steel plate. Shield must surround the bellhousing completely except for area of flywheel shield adjacent to differential and axle shaft. Shield may be multi piece with pieces bolted together using minimum 3/8 inch diameter Grade 5 or M10 class 8.8 bolts; may be attached to engine and or bell housing. in lieu of shield, a blanket meeting SFI spec 4.1 completely surrounding the bellhousing is permitted.
TRANSMISSION, AUTOMATIC:
All cars using an automatic transmission and running quicker than 10.99 or faster than 135 mph must be equipped with a transmission shield meeting SFI spec 4.1 a flexplate shield labeled as meeting SFI spec 30.1 and a flexplate labeled as meeting SFI spec 29.1. Transmission must be from same manufacturer as engine. Non OEM or aftermarket transmission prohibited. Transbrake prohibited.
TRANSMISSION, MANUAL:
Automated, timer type, pneumatic, electric, electronic, hydraulic,etc. shifting mechanism prohibited; each individual shift must be a function of the driver and controlled manually. (Driver must pull the lever.) Transmission must be from same manufacturer as engine. Non OEM or aftermarket transmission prohibited. Adjustable PRO STOCK type clutches prohibited.
3.Brakes and suspension
BRAKES:
Four wheel hydraulic brakes mandatory. Carbon fiber brake rotors prohibited. Staging brake allowed.
STEERING:
Must retain full, original, OEM steering gear.
SUSPENSION, FRONT:
Upper mounting point for strut assemblies must be in the factory location. Adjustable caster/camber pillowball mounts are permitted. Lower control arm may be strengthened provided factory mounting points to the chassis are maintained. Lower mounting point for strut assembly may be modified for improved caster or camber. Strut tower braces, lower tie bars, sway bars and limit straps are permitted. Traction bars/devices permitted; must be bolt on ONLY. Final decision rests with Technical Services.
SUSPENSION, REAR:
Must maintain original factory configuration. Aftermarket lower control arms, strut tower braces, lower tie bars, sway bars and limit straps are permitted. Rear suspension must maintain minimum shock travel of 1 inch. All rear suspensions must use at least one working shock absorber per wheel. Suspension modifications limited to bolt on items only. ALL OEM suspension mounts/attachment points must be utilized. Spindle mounts prohibited.
WHEELIE BARS:
Prohibited.
4.Frame
CHASSIS:
OEM chassis, with complete OEM floorpan and firewall mandatory. Wheel tubs, backhalf conversions, tube chassis, etc. prohibited. Must retain FWD configuration; rear drive conversions prohibited. Engine must be located in OEM location for body used. Non OEM tubing in front of firewall prohibited except to tie shock towers to roll cage.
GROUND CLEARANCE:
Minimum 3 inches from front of car to 12 inches behind centerline of front axle, 2 inches for remainder of car.
WHEELBASE:
Must retain original wheelbase for body used, plus or minus 1 inch. Maximum wheelbase variation from left to right is 1 inch.
5.Tires and wheels
TIRES:
26" X 10" max tire size.
WHEELS:
Must be automotive type wheels suitable for street or racing use. Minimum wheel size 13 inches unless originally equipped with smaller wheels and vehicle is equipped with original engine. Wheel studs must be threaded into hex portion of lug nut a distance at leas equal to the diameter of the stud. Spindle mounts prohibited.
6.Interior
INTERIOR:
Complete interior, including: dashboard, door panels, headliner, carpeting, etc mandatory from the front seat(s) forward. Interior panels behind the front seats are optional. Only 1 seat required, must be upholstered. Factory controls for lights and windows must be retained and operative.
7.Body
BODY:
Body must be on accepted bodies list. Pickups and SUVs prohibited.
Mild customizing and body kits permitted but must retain full bodied appearance with minimum 2 functional doors. Chopped roofs prohibited. Hood scoops or openings permitted. Doors must open and close from inside and outside. Windshield and all windows must retain OEM safety glass. No lexan permitted.
Lightweight body panels limited to hood, fenders and deck lid. Aftermarket body kits permitted but full street legal appearance must be maintained. One peice aftermarket front end prohibited. JoJo/CFT/Exospeed 3 piece front ends allowed. Air intake may not extend past the front bumper
FIREWALL:
Complete OEM firewall mandatory. Mini tubbing prohibited
FLOOR:
OEM floorpan, front to rear, mandatory.
STREET EQUIPMENT:
Both taillights and at least 1 headlight mandatory. Must be operative.
WINDSHIELD/WINDOWS:
Complete OEM windshield and windows mandatory. Windows must be operative per factory specifications. (Must open and close via electrical or OEM mechanical means.)
Tow vehicles prohibited.
According to my rules.... Drysumps / mechanical fuel pums / and strut style rear setups are fair game.
Old Mar 9, 2011 | 08:13 AM
zakura R's Avatar
Minimum weights
Class Requirements
1.Engine
ENGINE:
EXHAUST:
Optional.
FUEL:
TURBOCHARGER:
2.Drivetrain
FLYWHEEL SHIELD:
BRAKES:
STEERING:
SUSPENSION, FRONT:
SUSPENSION, REAR:
WHEELIE BARS:
Prohibited.
4.Frame
CHASSIS:
GROUND CLEARANCE:
WHEELBASE:
5.Tires and wheels
TIRES:
WHEELS:
6.Interior
INTERIOR:
7.Body
BODY:
FIREWALL:
FLOOR:
STREET EQUIPMENT:
WINDSHIELD/WINDOWS:
That is some good info right there thanks
Old Mar 9, 2011 | 10:37 AM
Garage 808 Hatch's Avatar
In the car is fine, Id speculate most are placing it out in the front of the car to add weight over the front tires. but thats just me thinking out loud
Old Mar 9, 2011 | 12:54 PM
Enzo-Racing's Avatar
Keeping rules simple is the way to go..
it's an outlaw class so it should have "outlaw" rules...
Old Mar 9, 2011 | 12:58 PM
MrParks's Avatar
Old Mar 9, 2011 | 07:30 PM
CNC HMA's Avatar
According to my sources if I have those items I might as well add Lexan and bars... But in this day and age I think those items are unnecessary. Unfortunately my wallet says I have to use what I have for now.
Old Mar 9, 2011 | 07:37 PM
tony1's Avatar
There IS still a Hot Rod class out there.
It's one thing to have a car built and rule changes keep you from racing.
It's another to build a car when rules are in place and then bitch about what you want to do not being legal. Want to run a dry sump, custom suspension, and mechanical fuel pump, great, but don't bitch that the class you want to run in doesn't allow them. Build to the class you want to run or build to the class the car you want to build fits into.
No offense Howard.
Old Mar 9, 2011 | 07:42 PM
CNC HMA's Avatar
No offense Howard.
No offense taken... No bitch'n either. Just poking at it, doing my research that's all And seeing where the rules are coming from.
Old Mar 9, 2011 | 07:46 PM
tony1's Avatar
Really doesn't matter where they're coming from, they're in place and have been working well.
I'll go out on a limb and say a dry sump will not be legal in this class in the next 3 years. Mechanical fuel pump, maybe.
Old Mar 9, 2011 | 07:55 PM
What's the big deal about a dry sump? I know If I was spending big money on my engine I wouldn't want to run without one.. And honestly this class has what? one race a year? Might as well go all out right?
Old Mar 9, 2011 | 07:56 PM
CNC HMA's Avatar
Hopefully the vote for the mechanical fuel pump goes well...
Old Mar 9, 2011 | 07:58 PM
what performance does a mechanical pump offer anyway? Should've been allowed from day one..
Old Mar 9, 2011 | 07:59 PM
tony1's Avatar
I'm done, these rule discussions are always like talking to a wall. lol
Old Mar 9, 2011 | 08:02 PM
CNC HMA's Avatar
HondaTech needs a Poke button... Hehe
Old Mar 9, 2011 | 08:34 PM
LOL...
Old Mar 9, 2011 | 11:14 PM
TrueStreetVW's Avatar
Does anyone have the rules breakdown like that for true street?
Old Mar 10, 2011 | 02:09 AM
Jason Miller's Avatar
We run Outlaw Street at the World Cup Finals every year and we will also be running it at the Import Revolution as well. NSCRA also runs it in their series.
Old Mar 10, 2011 | 09:26 AM
sgnlab's Avatar
Old Mar 10, 2011 | 10:51 AM
miller's Avatar
Old Mar 10, 2011 | 11:26 AM
JayWest's Avatar
talk about 1up'd ^
rayray24
Apr 2, 2013 09:12 PM
Nayr
Jun 15, 2007 08:20 AM
USDM.LOVE
Feb 11, 2007 03:56 PM
Brent L
Oct 4, 2006 11:00 AM
