I have a TSX Motor and a spare Type S K20A2 Head (Is it worth the head swap or not??)
Old Mar 8, 2011 | 07:25 PM
CRAZY-EG9's Avatar
Icon2 I have a TSX Motor and a spare Type S K20A2 Head (Is it worth the head swap or not??)
I have a 04 TSX Motor and a spare Type S K20A2 Head. I've been reading mixed answers about the type S K20a2 head casting vs the TSX K24a2 casting but it's not costing me anything except maybe a headgasket to swap. The TSX is going in my car, is it worth putting the type S head on the TSX motor. If not that is it atleast worth putting the Type S cams in atleast because I will be running around stock for a while, so I want to get the most pwr outa what I have for now??????????????????????
Also some say the heads perform the same but what makes me wonder is when being sold type S heads go for about 600-700 but TSX heads go for about 450-550. Just something that makes me wonder???
Old Mar 9, 2011 | 08:56 AM
ReDemoN's Avatar
DixielandImports Please
Default Re: I have a TSX Motor and a spare Type S K20A2 Head (Is it worth the head swap or no
I think its because the type s head is easier to work with. (Intake manifold I think)
Old Mar 9, 2011 | 12:59 PM
CRAZY-EG9's Avatar
Old Mar 29, 2011 | 11:25 PM
jdoc325's Avatar
I'd say its a good idea.. seeing as the type s head has "vtec" on its exhaust side as well... The TSX motors were built with lower compression and more stroke to make tq in order to get it moving...The cams and valve overlap on k24's were addressed accordingly
The K20A2 head will give your motor the free flowing peak hp it desires (Not to mention the 04' TSX utiizes drive-by-wire throttle body which i don't believe is compatible with K-pro) This along with its proven power increases and tune-ability is the reason they are more sought after on the street
Old Apr 5, 2011 | 08:53 PM
willymccoy's Avatar
The type S head flows more CFM and would be better if you are thinking of upgrading cams/exhaust/headers/bolt ons.
Old Apr 18, 2011 | 02:55 AM
zellogg3's Avatar
depends on the year tsx if its a 06 08 dont change the head.
06 08 tsx is better then the k20 head...
tsx is not a low compression motor...
fact not guessing
Old Apr 18, 2011 | 03:02 AM
PaNcakdEJ1's Avatar
fact not guessing
Not saying you are wrong in anyway but you should post something behide you statement being you say its a fact
Old Apr 18, 2011 | 05:56 AM
J35monster's Avatar
Just an FYI the crv head and k20a2 head have the same ports aswell as intake manifold flange. The only difference is the rsx head has true Vtec where the crv head has one cam Vtec, easy fix run the rocker assembly from the k20a2 head on a crv head. Here's my reasoning.
Sell the tsx head about 500, sell the rsx head without the rocker assembly for about 400. Pick up a bare crv head for 50-75...I have bought 4 of them at 50 a pop. Use the rsx rocker assembly on the crv head. Then the extra cash u have from selling both the rsx and tsx heads can pay for springs, retainers, and valves.
Just my .02
Old Apr 19, 2011 | 10:59 AM
K20EF8's Avatar
fact not guessing
wrong, the K20 PRB head is superior
Old Apr 20, 2011 | 06:55 PM
darrinbrewer's Avatar
i just dont see this... i'm going to put some ACTUAL FACTS to this thread.
04/05, and the 06-08 heads have REAL vtec,
not like a crv/accord (new 09+ tsx's unfortunatly fall into this category now)
06 to 08 heads HAVE 1mm OVERSIZE intake valves already, and come stock with a nice 64mm dbw throttle body
tsx heads can readily accept the RRC manifold WITHOUT MODIFICATION, rsx-s heads have to have the side machined/cut off, and run a coolant adapter.
i ran across threads (dont have a link) to
a 06-08 head (with 1mm bigger valves) outflowing a lightly ported k20 head.
wikipedia says k24a2's are 10.5:1 compression, and the k20a2/ z1/z3's all being 11:1
I picked up a full k24a2 (2006) to drop in my 07 si, and have had many shops advise that there was no performance gain to be seen in swapping heads
(just use a 50deg vtc gear)
Old Apr 23, 2011 | 09:58 PM
TheShodan's Avatar
Moderator
Not hard to find:
K24A2
* Found in:
o 2004-2008 Acura TSX, JDM CL9 Accord Type-S, RB1 Odyssey Absolute
+ Displacement: 2,354 cc (143.6 cu in)
+ Power: 200 PS (150 kW; 200 hp) @ 6800 rpm
+ Torque: 232 N·m (171 lb·ft) @ 4500 rpm (166 lbft @ 4500 rpm U.S.)
+ Bore: 87 mm
+ Stroke: 99 mm
+ Compression: 10.5:1
angelSIR-G
Acura TSX
19
Mar 18, 2006 10:29 PM
DBallz
Apr 30, 2003 07:26 PM
