h22 accord obd2 ecu????
Old Mar 8, 2011 | 04:11 PM
accordmatt's Avatar
Default h22 accord obd2 ecu????
ok so l have a p13-a12 ecu for my obd2 h22 swapped accord. my ? is can l get a tuned/chipped/cromed ecu to work with my obd2 componets? l know they dont make obd2 ones really but if they do where? and if obd1 will it be compatible with what l have so l can just swap ecus after emissions and not a bunch of other stuff??????
Old Mar 8, 2011 | 04:16 PM
TheMuffinMan's Avatar
He knows where you live!
Default Re: h22 accord obd2 ecu????
No, you have to run a piggy-back system in addition to the OBDII ECU. Alternatively you downconvert to OBDI and will be able to have a chipped ECU like a P28. Keep in mind some piggy-back systems can mess up the OBDII port as well, so readings may not work correctly for emissions.
You are better off just staying OBDII and staying compliant. There really isn't a need for you to go OBDI unless you are doing some heavier modifications.
Old Mar 8, 2011 | 04:49 PM
accordmatt's Avatar
well lm running VAFC2 right now. l have a good bit of parts waiting to go on and lm trying to figure a better way of running what l want. l cant really run bigger injectors with current ecu. or advance or retard dizzy. simple stuff l would like to do my ecu wont let me
import_tuner13
Nov 12, 2011 01:03 AM
tgreene2098
Aug 27, 2009 03:09 PM
3litre190
Jul 25, 2007 01:47 AM
rollercosta123
Jan 3, 2007 10:40 PM
SprayinCX
Mar 27, 2005 07:32 PM
