injectors for my turbo integra
hey guys im turboing my b18c1 and was wondering if the injectors i purchased would be enough for wut im shooting for
like i said its a b18c1 im only going for 325-350 whp and i have 550cc rc injectors
i did the calculations through RC's website and it seems like im wayyyy short
also they give u the fuel pressure set automatically at 43.5PSI so im also wondering wut kind of fuel pressure i can make with a Walbro 255lph fuel pump on a stock fuel rail in order to compensate for my lack of injector size and also if the saturated 550's can handle and higher pressure.
since were on the topic wut break specific fuel consumption will my engine require to make the horsepower im shooting for?
mayb i should put this in engine management and tuning but i figured i mine as well start here
thanks!
thanks!
Listen to Mac! The 550's will do the job but thats about all there capable of. The calculations on the RC site gives you a 30% window for a safety margin. Maxing them out or just about will get your goals. If your concerned with this then stop complaining about the rc calculations and get larger injectors
IMO go larger on injectors you wil always want more power and having larger will give you room to grow. id or fic 1000's ftw
I would always go bigger when buying injectors because you WILL end up wanting to make more power down the road. Phearable.net says 550cc = 330whp-380whp
thats the link i used to calculate...i calculated everything with the 80% duty cycle i heard anything over that isnt good....and i typed in 60 for the brake specific and 70psi and thats how i got into my range
Like i said the RC calculations give a 30% window safety margin. Like lightning said people have pushed 450's to 350whp. 550's will do just fine. set your static base pressure at 50 psi for a little added security and your good. its not like the engine is going to blow up. you will just run out of fuel if anythign and not be able to tune past a certain boost pressure. or if your really concerned sell the 550's like i said before and go larger thats your options
Haleiwa-Brando
Sep 3, 2005 12:31 PM
ATS*Mark
Aug 7, 2004 10:12 AM
