car shooting out thick white smoke. need help
Old Mar 8, 2011 | 01:49 PM
jeresaur's Avatar
Default car shooting out thick white smoke. need help
my 95 gsr has a previous blown headgasket ..but just the other day i added a little oil and the car started smoking alot through the exhaust and started putting...when i started accelerating more smoke came out so i pulled over and left the car at my couzins..what do you think the problem could be ?head gasket? a shop said headgasket and vavle job would be 950....750 for the headgasket repair
thanks
Old Mar 8, 2011 | 01:54 PM
Spawne32's Avatar
Default Re: car shooting out thick white smoke. need help
white smoke? blue tinted smoke? does it have a sweet smell to it? sounds like a head gasket imo, if they dont remachine the bottom of the head at least, the new gasket wont seal properly, imo it cost alot less to do it yourself if your any sort of mechanically inclined
Old Mar 8, 2011 | 02:06 PM
Necromonger's Avatar
White smoke? Does it condensate or disappear? If so it is probably coolant. If not, it could be some other fluid like transmission fluid if it is automatic.
Check your radiator for oil and check your dipstick(no not that one, the one on the engine) for water. If the oil is runny on the dipstick, you definitely have an engine problem. Could be head gasket which is relatively easy to fix or could be cracked block which is RIP engine.
Old Mar 8, 2011 | 02:14 PM
SubversionX's Avatar
Do a compression test; sounds like you may have a blown hg. Not to jump to assumptions though. Does your oil look milky? Is your coolant contaminated? Please don't pay nearly a grand just to change your hg. Just get a torque wrench and a gasket kit.
Old Mar 8, 2011 | 02:33 PM
Spawne32's Avatar
transmission fluid....in the exhaust
Old Mar 8, 2011 | 03:09 PM
Yes.. It can get into the engine. We diagnosed a vehicle with this problem like 2 semesters ago. We thought it was coolant but it wasn't. This only happens on auto trans though. Although it could also happen on manual trans, as water can get into the transmission housing and going through one of the bellhousing seals into the crank case where it gets picked up by the oil pick up and pump.
Old Mar 13, 2011 | 04:07 AM
ej8_99's Avatar
hmm that really sounds logical. i was so brain f***ed just now trying to figure out how transmission fluid get to the motor lol. but i agree, please dont pay that much for a head gasket replacement. its so simple
Old Mar 13, 2011 | 04:24 AM
lostforawhile's Avatar
longest project ever
From: on the south side of dixie, 1986 Accord Hatch
it's very unlikely that water or manual transmission oil is going to go up against gravity and force itself through a seal, AGAINST oil pressure and magically make it's way into the engine, manual oil isn't pressurized, it's just going to leak out the case, usually auto fluid gets into the engine from a vaccume modulator on a transmission, diaphram fails,and vaccume sucks fluid into the intake. something else to look at, is your throttle body, most are heated with coolant, and a gasket leak or a crack will let pressurized coolant into the intake. I wonder how many early hondas were scraped, or needlessly fixed due to the coolant passage in the carburator? O ring fails, coolant is sucked into intake, car billows white smoke, must be a head gasket!! some honda's also have an oil cooler in the filter base with, guess what? coolant running through it. O ring fails, coolant gets in oil, must be the head gasket!!
Old Mar 13, 2011 | 05:00 AM
ej8_99's Avatar
^^smart guy
changed my mind about that
20mph
Sep 30, 2015 07:42 PM
mannydhanju
Feb 21, 2009 09:33 PM
lmike6453
Oct 16, 2007 11:18 AM
4dr*sleeper
15
Aug 1, 2005 02:08 PM
sambam27
Dec 5, 2004 09:39 AM
