Honda S2000 Honda S2000
S2g stock wheel weight?
Old Sep 26, 2002 | 11:37 AM
DsITR's Avatar
Default S2g stock wheel weight?
Ayone know how much s2000's stock wheels weight. and are they the same bolt pattern as a 5th gen lude. 5x114.3?? if so anyone wanna sell their stock wheels??
D
97SH
Old Sep 26, 2002 | 11:41 AM
SECRET AP1's Avatar
Default Re: S2g stock wheel weight? (dsludefosho)
i do know it's the same bolt pattern as the lude/itr [5x114.3], but i do not know the weight nor am i selling mine
you will not be able to use the rear wheels though. you will need to get 4 front wheels if it's going on a lude
Old Sep 26, 2002 | 12:09 PM
jerrypeterson's Avatar
Offsets and wheel widths also come into play. The rear wheels won't fit because of this. (Unless you have some sort of wide-body kit. You can hop over to s2ki.com and search for a set of wheels, but you need wheels from two sets for the prelude.
Fronts are around 17lbs. Some where in there.
Old Sep 26, 2002 | 12:19 PM
schwett's Avatar
New User
16 x 6.5, 17.5lb front
16 x 7.5, 18.6lb rear
5 x 114.3
don't know the stock offsets but it's fairly high. the fronts would fit a 5th gen. weight savings is minimal - 2 lbs / wheel.
[Modified by schwett, 1:20 PM 9/26/2002]
Old Sep 27, 2002 | 07:13 AM
DsITR's Avatar
Default Re: S2g stock wheel weight? (schwett)
thanks for the help yall, im going w/rota's i think
D
97SH
Z99doc
Oct 11, 2015 03:50 PM
GoLowDrew
Aug 11, 2008 08:18 PM
abercrombemonkey
Nov 3, 2005 12:20 PM
kiss_kiss_kill
Jun 28, 2005 07:24 PM
damonk
Nov 22, 2004 10:41 AM
