Interior dome light comes on around turns!!!?
Old Mar 7, 2011 | 06:38 PM
ksuth88's Avatar
Icon2 Interior dome light comes on around turns!!!?
I bought my 99 LS last August. Ever since i have had it i have a problem every once and awhile. This does not happen all the time but when i take a right turn or hit a bump in the road, my interior dome light comes on. I know it is my drivers side door because sometimes i just set my knee against the door while driving and it makes it come on.... I can sometimes open and close the door hard to make it go away, but not always. During the day this does not bother me but driving at night, this gets really annoying!!! Can anyone help me? What is wrong here!
Old Mar 7, 2011 | 06:43 PM
MD426's Avatar
Default Re: Interior dome light comes on around turns!!!?
Sounds like the switch in the door jam is loose, there should be a rubber covered pin that sticks out near the door latch. Atleast I think it's a Pin on the newer models, DA integras have a slide switch.
Old Mar 7, 2011 | 06:47 PM
ksuth88's Avatar
Yeah, i checked that and it looks fine. It doesn't look worn at all. I guess i will have to look at it further. Thanks.
Old Mar 7, 2011 | 06:50 PM
91_LS's Avatar
Pull the switch out and check the wire bro,the wire might of came off or its loose and grounding out on turns.
Old Mar 7, 2011 | 06:56 PM
mark@silbernage's Avatar
Any chance the door's latch mechanism is loose (or the loop it connects to on the door frame)?
Does the door move much when you push/pull by hand (window down, door closed)?
Mark
Old Mar 7, 2011 | 07:12 PM
ksuth88's Avatar
Oh nice, i will pull out the switch and check the wire. I didn't even think about that. Thanks. No, the door does not move really at all. I will look into this further and let you guys know how it goes.
Old Mar 7, 2011 | 07:28 PM
turboacurab20's Avatar
if u dont have any loose wires id replace the switch u can probably get one at junk yard for $5 or so / on my 95 integra it has switch next to dome for on /auto/ off , try switching it to off
Vagitarian
46
Aug 11, 2012 03:58 PM
lovemyintegra1
Jul 16, 2007 11:47 PM
Silent_Destruct
Nov 26, 2006 07:02 PM
deeksmooth
Apr 8, 2004 01:04 PM
CRiSP
Sep 25, 2003 03:16 PM
