Best cams for what ive built
Old Mar 7, 2011 | 05:49 PM
slofton77's Avatar
Default Best cams for what ive built
2000 civic ex
Engine is a Gsr obd2b B18c1 and mods are..............
Pistons: OEM JDM ITR 81mm
Rings: OEM 81mm
Rods: Eagle H Beam
Valves: Supertech Flat Top
Springs/ Retainers: Supertech
Bearings Rod/ Crank: ACL race Bearings\
Head Gasket: OEM GSR
Intake MF: Skunk2 Pro
Headers: Weapon R
Throttle Body: Stock GSR
Clutch ACt Stage 4 6 pluk
Waterpump: OEM GSR
Oil Pump: OEm gsr/ Type R
ECu: Stock p2t b16a2 with less than 60k on it
Im planning on buying a 68 TB but im tryin to figure out what i should run with my build . Im also tryin to get a CTR ecu that is obd2b or a ITR obd2b.
So honda tech let me know something what should i do for the best cams for a DD. And if anyone has any good deals let me know.
Email: slofton77@yahoo.com
Old Mar 8, 2011 | 03:02 AM
slofton77's Avatar
Default Re: Best cams for what ive built
wow 40 views and not even a bump wtf? Does anyone have anything to say?
Old Mar 8, 2011 | 03:23 AM
Libertariat's Avatar
Ek Forever y0!
Your intake manifold and header is junk. Marginally better than the OEM.
Check the all motor forum, the common recommended all motor cam for a street car is some variation of the Skunk2 Pro-series.
Really though, ditch the intake manifold and header. That money would be spent better in retaining the OEM intake manifold and buying a quality header like an RMF narrow or SMSP. Reverting to the OEM intake mani and adding that header will likely result in a net gain.
Don't whine about not getting a response when you're posting in the wrong forum. This is a 92-00 technical forum. There's nothing in here that pertains to a 92-00 civic. The all motor or FI forum even will have a plethora of advice for you.
Old Mar 8, 2011 | 06:23 AM
redef90si's Avatar
bump
CRISxMOB
Feb 4, 2012 09:37 PM
slofton77
21
Mar 10, 2011 01:09 PM
1990_crx-si
Jun 13, 2009 07:00 PM
NABeastRR
Jun 23, 2008 09:02 AM
NABeastRR
Southeast (Sales)
Jun 23, 2008 09:01 AM
