ENGINE NAME TAG
on a F20A engine tag or tag the piece that is part of the engine block where the engine id is stamped....anyway it says
and wikipedia says
Specifications
Bore × Stroke: 85.0 × 88.0 mm
Displacement: 1997 cc
Compression ratio : 9.5:1
Valve Configuration: SOHC, 16 valves
Max output : F20A2 110 PS @ 6000 rpm (carbureted)
Max output : F20A3 110 PS @ 6000 rpm (carbureted)
Max output : F20A4 133 PS @ 5400 rpm (PGM-FI)
Max output : F20A5 150 PS @ 5400 rpm (PGM-FI)
Max output : F20A6 90 PS @ 6000 rpm (carbureted)
Max output : F20A7 135 PS @ 5600 rpm (PGM-FI)
Max output : F20A8 145 PS @ 5900 rpm (PGM-FI)
Max torque : F20A2 16.1 kg m @ 3800 rpm (carbureted)
Max torque : F20A4 18.5 kg m @ 4300 rpm (PGM-FI)
Max torque : F20A7 19.3 kg m @ 4400 rpm (PGM-FI)
Max torque : F20A8 138 ft/lb @ 4400 rpm (PGM-FI)
there are different ver of the motor which one is mine
F20A
1908757
1908757
and wikipedia says
Specifications
I think the '1908757' corresponds to the vehicle VIN code.
