battery wont stay charged
Old Mar 7, 2011 | 08:36 AM
Wingate457's Avatar
Default battery wont stay charged
I know i did something wrong. Battery relocate was too simple. My battery keeps dying after I put it in my trunk. When I use the jumper box it starts right up. I just connected the wires and ran them back to my trunk. Where did I go wrong?
Old Mar 7, 2011 | 09:04 AM
Surfjunkie44's Avatar
Default Re: battery wont stay charged
First and foremost, do you have a solid ground connection and are the terminals clear of corrosion? Secondly, is the alternator producing a proper charge?
On a side note - I have never personally done a battery relocation and am a horrible electrician, thus I cannot account for the factuality of the following statements. I have read multiple forums discussing the necessity for a larger than stock gauge wire to accommodate the distance change of a battery relocation to the trunk.
Old Mar 7, 2011 | 09:16 AM
4drEF's Avatar
Keyboard Humorist
Is it the same battery that was working when you had it under the hood?
When you start it with the jumper box, are you jumping from under the hood or from the trunk?
Old Mar 7, 2011 | 11:31 AM
Wingate457's Avatar
Yes it is the same battery that worked fine under the hood. And I am jumping it from the trunk
Old Mar 7, 2011 | 02:18 PM
4drEF's Avatar
Keyboard Humorist
What gauge is the power wire?
What is the ground attached to?
My guess is your ground location. I had similar issues where I was getting weak power. Try bolting the ground to the spare tire tie down or under one of the nuts on the back where the taillights are. Make sure paint is scraped away well so you get good metal to metal contact.
Old Mar 10, 2011 | 03:39 AM
I feel ever so slightly ignored with the redundancy of my questions, but c'est la vie. 4drEF, you seem knowledgeable on this matter - is a larger gauge wire required for the battery relocation, and if so, what size is the minimum recommendation?
Old Mar 10, 2011 | 03:49 AM
cetcivic's Avatar
no one wants to hear the truth
Time to ball out..get a SPOON battery,put it back under the hood,then take pics and post it in the SPOON parts thread.
navi510
Jul 6, 2017 08:53 PM
civics4lyfe
Jan 23, 2009 03:19 PM
5150CIVIC
Audio / Security / Video
10
Mar 25, 2008 06:46 AM
jakeiscool
12
May 21, 2005 12:04 PM
