tranny swap easy both ways?
Ok so I have automatic 98 lx and friend at work has 96 lx manual, he wants auto and I want manual, I've seen the tread auto to manual but is it just as easy to go the other way? With both cars side by side how long should this swap take,(all of experienced mechs), do we have to pull motor or no? Or do we just swap everything like it is and everything should bolt up?
swapping cars would be easier.
take into account switching of axles ( same for man tranny?) and radiators, i think other than that it shouldnt be much more work. It def. is more work since your doing a conversion on 2 cars instead of just removing and installing on 2 cars.
Dont have to pull the motor....just get it stabilized with a support bar ( dont know the real name of that tool lol) and your good. Drop it from the bottom. and if your following the auto to mani guide then you will be fine, the man to auto is all bolt up.
Because you have to pull the dash, the heatercore, A/C and anything else under the dash so you can swap the underdash harness, the dash harness, and the engine harness for an automatic. You can easily mod an automatic harness to work with a manual, you just have to screw around with the starting circuit and backup lights, going the other way you have to swap harnesses.
EDIT: psych!
my stand on these swaps in general though.. more often it's better/easier to just sell the car you have and buy one with the transmission you want. these are mass market cars and there are tens of thousands out there to chose from.
the two chassis are different. though the engines are very similar and most things can be made to fit, the difference in wiring for the auto box could be a nightmare. manual to auto for the same chassis and same year is troublesome enough like some of the other posters have stated.
Op, I wouldn't do this, trade cars with the guy or find another donor car for yourself.
All-Integra20
Oct 11, 2012 05:25 PM
uenolove
Feb 27, 2008 04:32 PM
stock96accordlx
Dec 1, 2007 08:14 PM
ericjackson
Jun 21, 2005 01:52 PM
