honda accord 00 f23 to h23 vtec dohc
Old Mar 6, 2011 | 04:27 PM
cashkidd19's Avatar
Default honda accord 00 f23 to h23 vtec dohc
Iam doing a engine swap to my honda accord 2000 4cy ulev vtec to a ob2 h23 vtech i have it in but i ran in to a couple of problems first with the distributor i need help on bypassing the distributor wire from my original harness to the distributor on the h23 because the distributer on the h23 will not fit... also i need to no what year and make steering wheel pump and bracket is compatible with this engine also will there be any error messages when my car finally gets to start up because i havent got a chance to be cause of the wiring problem with the distributor and yes i do have the h23 ecu please help iam out of transportation because of these small issues ps ho do i connect my ac compressor connections because there kinda diffrent and what year and modle belt with work on the it and the steering pump???
Old Oct 5, 2013 | 02:48 PM
T6GEX's Avatar
Default Re: honda accord 00 f23 to h23 vtec dohc
Did you ever resolve the problems with the swap, if so advise.
hondaaccordf23
Mar 19, 2012 07:53 AM
spoolin4life
Apr 24, 2011 04:42 AM
Ethan2536
Jan 5, 2010 07:24 PM
Midnightrayne
Jun 3, 2005 08:43 AM
