advance your timing, what does it do?
Old Sep 26, 2002 | 09:51 AM
civickid77's Avatar
Default advance your timing, what does it do?
When you advance your timing what acctually happens? what does it do?
Old Sep 26, 2002 | 09:58 AM
ciRcuitJerk's Avatar
jus f0 dekarayshunZ
Default Re: advance your timing, what does it do? (civickid77)
https://honda-tech.com/zerosearch
try finding the answer in there ...
Old Sep 26, 2002 | 10:05 AM
X2BOARD's Avatar
Default Re: advance your timing, what does it do? (CiRcUiTsi)
Simple, no need to search... heh....
It allows the distributor to initiate the spark earlier in the combustion cycle, thereby allowing more time for flame propogation (burn), resulting in better fuel economy and more HP/Tq.
However, you need to remember that advancing timing too much will result in more heat being present during every cycle, increasing the chances of detonation. Which is why you should only run advanced timing when using premium gas (more detonation resistant)
X2
bopbop93030
Feb 24, 2009 02:57 PM
kixcrx
Nov 10, 2006 10:33 AM
MKIIISupra
Aug 7, 2005 04:38 PM
98slvrcx
Jul 28, 2002 09:58 PM
kahren
Oct 16, 2001 10:58 AM
