My odometer stopped working need help!!!
Old Mar 6, 2011 | 10:16 AM
retrokidgeo23's Avatar
Icon6 My odometer stopped working need help!!!
Ok i have a 2000 honda civic hatchback cx and everything on my cluster works except for the odometer miles and the other odmeter on top. Other than that everything works.. can it be a fuse or just a bad cluster...
Old Mar 6, 2011 | 10:23 AM
ej1916's Avatar
Default Re: My odometer stopped working need help!!!
I'm sure people are going to tell you to google search before you post because this is a common thing in hondas. But I had the same problem and researched the hell out of it. Could be a fuse or the cluster. Could be the vehicle speed sensor itself or bad/loose/corroded wiring somewhere. Check for visuals first then take out the multimeter and start testing if you cant find anything wrong visually.
Carlos Calderon
Jan 30, 2016 08:02 AM
jeremyrocksursox
14
May 27, 2009 10:05 AM
RaWrZie
Jun 3, 2008 10:43 AM
slotec
Jun 16, 2004 05:55 PM
Endless
Nov 17, 2002 09:44 PM
