Suspension & Brakes Theory, alignment, spring rates....
Energy Suspension bushing kits
Old Mar 6, 2011 | 06:45 AM
amej8's Avatar
Default Energy Suspension bushing kits
Current setup:
99 civic ex, stock engine, I/H/Si muffler, 216,xxx miles
Tokico Illuminas
Eibach Sportlines
22mm USDM ITR rear sway bar
ASR Subframe brace
16x7 +4x wheels with 205/45 S. Drives
My suspension components are worn. A little creak and clunking here and there. I was looking at the ES master bushing kit and it's just way too much for me. Both cost and bushing wise. So I was wondering if there are any specific bushings I should look at replacing. I was thinking the rear sway bar bushings since they're OEM rubber. Anything else?
Edit - Or is it just better to get new motor mounts (OEM, I don't need poly for performance and I certainly don't need the vibrations for a DD) and the poly rear sway bar bushings.
Old Mar 6, 2011 | 09:11 AM
98civdx's Avatar
Master Detailer
Default Re: Energy Suspension bushing kits
You can buy seperate bushing sets.
Like if you would just want front LCA's or trailing arms.
I have ES bushings on my SI sway bars front and rear in my car. I have no problems with them.
Personaly, I would never buy the master kit. It comes with stuff that I don't want.
Old Mar 6, 2011 | 12:16 PM
abs0Lut's Avatar
First thing your going to want to do is figure where the creaks and clunking are coming from and if it's just a couple bushings buy brand new from Honda because I don't think it would make sense to have poly bushing on your left side LCA and not on the right(for example), I see that screwing around with your steering and handling.
Old Mar 6, 2011 | 04:24 PM
amej8's Avatar
I would never put one part in one side and another in the other side. When I fix things, I get it done the right way the first time .
I think I'll just stick to sway bar bushings, new end links, and new motor mounts. My engine rocks like crazy causing my car to jerk a lot when I let off/press the gas.
Old Mar 9, 2011 | 10:48 AM
ek9civichb's Avatar
check the rear lca for the big round mount in the middle the on that bolts to the body that one always cracks you have to press it in
ScottF
Sep 17, 2012 04:15 PM
jonesEK
May 26, 2010 09:16 PM
CYBEREXII
May 27, 2003 10:00 AM
wakaru
Jul 20, 2002 03:39 PM
