Just bought a JDM EG9 cluster... DID I get the shaft?
Old Mar 5, 2011 | 05:54 PM
JDM_rolex's Avatar
Default Just bought a JDM EG9 cluster... DID I get the shaft?
Just bought one on here. I installed it and the RPM gauge is off by 1000 rpms. My car idles smooth at 1000rpms, but after I installed it the gauge reads 2000 at idle. WTF?? Did I get the shaft?
Any ideas on what I can do to fix the problem?
Old Mar 5, 2011 | 06:18 PM
Black Diamond's Avatar
Default Re: Just bought a JDM EG9 cluster... DID I get the shaft?
Pics of the cluster? And what kinda car are you tring to put it in. I do realize its a Jdm cluster but the RPMS dont change... I have a Jdm eg6 cluster in my car and it didnt change when i swapped it in.
Old Mar 5, 2011 | 06:56 PM
JDM_rolex's Avatar
This is a JDM EG9 Ferio cluster. I put it into my 92 civic sedan.
Old Mar 6, 2011 | 08:21 AM
deschlong's Avatar
Oh look, I can change this
Loved
Community Favorite
Could be incorrectly calibrated .. maybe p.o. dicked around with the needle. Anyway, here's how you fix it: http://honda-eg6.blogspot.com/2010/1...on-how-to.html
Reproduced below for posterity:
RPM Meter calibration - how-to
My rpm was not reading correctly. I compared the reading to my APEXI VAFC and based on the gearing calculation versus the speedometer reading.
I did a searching on the internet on how to calibrate and all the information I got was to remove the needle, set the car at idling & plug it back, which I didnt want to do as it might damage the meter.
I was thinking how did the manufacturer did it. I remove the meters from the clusters and found the answers!
If u take a look at the top of the RPM meter, u will see 2 potentiometer aka pot (variable resistor). This is where u can do the calibration or adjustments.
Since it cant be adjusted once it installed back into the clusters/casing. I used crocodile clips to connect to the back of the clusters to get the signals.
Next step is to start the engine and adjust the resistors by comparing to my VAFC readings. Frankly speaking, I do not know the reason for the two pots. Anyway with the meter facing you, turning the pots anti-clockwise will lower the rpm reading. If u max out one of the pot, and the rpm is still too high, just turn the other pot also.
Instead of using VAFC, u can try to borrow a RPM meter that is known to be accurate and use it as a reference.
Hope this will help most of you who have inaccurate rpm readings.
Old Mar 6, 2011 | 08:24 AM
speedooo's Avatar
innacurate eg tach? unheard of! i hope you got the sarcasm....DeSchlong has the info you need.
Old Mar 7, 2011 | 07:17 AM
JDM_rolex's Avatar
Thanks guys, I will try this out and let you a know!
BolivianDc2
Apr 23, 2002 06:00 PM
OmegaLS
Nov 10, 2001 10:10 PM
