Jdm B16 Sputters at Certain RPMs
Okay, I have a jdm b16 motor I bought from hmotors. The motor had about 50k miles on it when I bought it, and I've put about 3100 miles on it so far. This might sound weird, but the car hesitates/sputters when I push the pedal in past a certain point at 2500-2700 rpm, at about 3100 rpm, and about 4000 rpm. After 4000 rpm, I can accelerate normally no matter how far I push the accelerator, whether it be to the floor or if I ease into it. My spark plugs and wires, fuel filter, walbro pump, and distributor cap and rotor have about 3100 miles on them. Can you guys think of what could be causing this like bad ignitor, coil, tps sensor, etc? Also, timing is set perfectly because my belt and tensioner were replaced quite recently as well by a friend. And I've checked for vaccum leaks as well. I don't have any. Thanks for any help you can give me guys.
I have also experienced random hesitation with a JDM b16. Like you I had it completely tuned up in every way. The engine ran great for years, but for some reason had the hesitation at times. Only at part throttle at lower rpm. I autocrossed with success and achieved excellent fuel mileage.
I recently discovered some burnt/worn parts inside the p30 ecu. Could have been the problem, although I dont run this engine anymore. Maybe check out your computer.
I know all of my grounds are good to go as well. I will look into o2 sensors though. Do jdm b16s(sir2) have 2(primary and secondary) o2 sensors? If they do, where is the other one besides the one on the exhaust manifold? Thank you.
Update: Went for a drive today and at certain times during the drive the car nearly came to a stand-still rpm-wise. I'd be going about 50 mph in 5th gear and the car just didn't want to accelerate any faster. I had to completely let off the gas and then push the gas back down a pretty good amount again. I also tossed out some pretty big backfires while shifting upwards to 7-8k rpm.
Did you TRY driving with the o2 sensors disconnected? Should rule them out entirely by driving without them attached, that way it'll be driving on pre-configured fuel trims. It'll run rich for sure but if it's still doing this issue, even to a smaller extent, you'll be able to rule that out entirely. Maybe you have a sticky IACV valve? hmm.. I dunno
impaktem1boy
46
May 21, 2008 09:15 PM
