Check light is on, jumped it. This is what I got
Old Mar 5, 2011 | 11:29 AM
tallguy21's Avatar
Default Check light is on, jumped it. This is what I got
Check light popped on and I read the stickie on it and it said it was suppose o pause for a 1/2 sec or full second. The pause between each blink was like 4 seconds.
It went over 92 blinks...I'm grtting the feeling I read that wrong. Anybody have any suggestions?
Old Mar 5, 2011 | 11:33 AM
grumblemarc's Avatar
The Grumpiest
Default Re: Check light is on, jumped it. This is what I got
You sure it's not just a constant blinking? What were you doing just before?
Old Mar 5, 2011 | 12:14 PM
NOFX's Avatar
H-T White Ops
Video?
Old Mar 5, 2011 | 12:30 PM
tallguy21's Avatar
I just asked a friend thats knowledgable on Hondas and he said the four second pause means it's starting over. If that's the case and it gave me on long blink from the sticky it might be a 02?
And it's not a constant blink, the pause is in between. I just took notice to the light last night. It was raining pretty hard out here and I noticed it then.
Old Mar 5, 2011 | 12:35 PM
NOFX's Avatar
H-T White Ops
One long blink would be a code 10.
The thread even uses that code as an example.
One short blink would be a code 01/code 1. Two short blinks would be a code 02/code 2.
Old Mar 5, 2011 | 01:10 PM
virgineg6's Avatar
Originally Posted by NOFX
Video?
x2 just to be on the safe side
Old Mar 11, 2011 | 09:13 AM
tallguy21's Avatar
sorry about such a late response...I have a video, but how can I go about posting it up?
Old Mar 11, 2011 | 09:43 AM
The Grumpiest
Post it to Youtube. Then post the link to the video.
Old Mar 11, 2011 | 11:46 PM
tallguy21's Avatar
hopefully this works lol
http://www.youtube.com/watch?v=0xwPKJguCcs
Old Mar 12, 2011 | 12:24 AM
Rylan's Avatar
Id say it's a code 10 IAT - intake air temperature sensor
Seems to have a long pause in between each flash.
Old Mar 12, 2011 | 02:09 AM
ricky00's Avatar
code 10.. get a new iat sensor or just reset ur ecu.. happen to my brother cars and we just reset it and it disappear
Old Mar 12, 2011 | 06:15 AM
Former User's Avatar
Looks like code 1 for the primary O2 sensor.
By the way OP, you should put information about your car in your signature as this is crucial to know for technical threads.
Old Mar 12, 2011 | 07:43 AM
CivicSpoon's Avatar
Looks like a code 1 to me as well. If it's a code 10, it should stay lit longer than that. The long pause definitely signifies that it's starting over, so you're throwing just 1 code.
Old Mar 12, 2011 | 09:22 AM
raidacaipo's Avatar
CORRECT!
CORRECT!
INCORRECT!
INCORRECT!
Old Mar 12, 2011 | 01:16 PM
tallguy21's Avatar
so consensus is o2...that's a plus...at least this way when I goto get tuned I can get that tuned out.
weird thing is the light hasn't turned on my last drive around today : /
figures it would do that...also the gas mileage magically starts to do a lil bit better by reading what the gauge has been saying. lol
also, for the IAT sensor, I was actually going to change it today but the guy that did the swap before me kept the ex sensor in there instead of using the 99-00 sensor...that normal?
Old Mar 12, 2011 | 02:07 PM
Kluiz's Avatar
code 1 : O2
First reset your ECU by remove backup fuse (7.5A) from under-hood fuse box or remove (-) battery terminal for 10 sec then put it back and test it. If it always throw code1 you need to check poor connections or loose wire or request your tuner for recheck to disable O2.
Old Mar 12, 2011 | 04:00 PM
tallguy21's Avatar
Originally Posted by Kluiz
code 1 : O2
is it the only 7.5a fuse sitting under the hood? Why isn't the fuse labeled for the ecu if that's the case? I know thats what everybody is saying, i'm just curious as to why it would be that way instead of actually labeling it that way
Loco-B
May 18, 2008 10:55 AM
ek98
Dec 24, 2007 08:21 PM
sireg6
Audio / Security / Video
May 16, 2007 11:51 AM
Arch-Angel
Jul 11, 2004 05:15 PM
