Tire Noise?
Old Mar 5, 2011 | 12:19 AM
HondaGuy951's Avatar
Default Tire Noise?
So I have a 1997 civic LX. It's been rather loud lately. I will be driving, and after about 10 mph, it will sound like I'm driving on 35" mud tires. Just a loud, deep hum that gets louder the faster I go. I jacked the car up and push/pulled on the wheels to check the bearings and there is no play at all, so I don't think its the wheel bearings. I'm running 16" Falken 912's rear, and Nexen N3000's up front. I do need to replace my cv boots bcuz they are ripped (could that be the cause of the noise?). Anyway, anyone have any input? Also there's no wobble noise that would be associated with wheel bearings being bad. Just a consistent hum that gets louder the faster I go. It sounds like a tire noise, but it just seems kinda loud.
Old Mar 5, 2011 | 12:23 AM
virgineg6's Avatar
Default Re: Tire Noise?
any changes in tires since the noise became louder?
Old Mar 5, 2011 | 12:49 AM
Yes, but noise didn't get louder. It stayed the same.
Old Mar 5, 2011 | 06:15 AM
98ekb16's Avatar
Sounds like bearings. I've seen several hondas with bad bearings that had no play at all. And def change the cv boots if they are ripped before the joints start clicking when you turn.
Old Mar 5, 2011 | 08:23 AM
fungus mungus's Avatar
How are your shocks? You might want to check them too...blown shocks will cause abnormal tire wear, which will result in excessive tire noise too. If it's your wheel bearings, you'll hear the sound coming from one or more corners of the car...when my left wheel bearing went bad, it sounded like I was being tailed by a papparazi on a 2-stroke mini bike.
fm
Old Mar 5, 2011 | 08:41 AM
JasonYo's Avatar
Some tires get louder when they start to wear out.
But it could also be a wheel bearing, they wont necessarily have play in them when they are worn. And a bad wheel bearing usually sounds like your on big mud tires.
Tony Cameron
Dec 11, 2013 06:31 AM
JennAMP
Transmission & Drivetrain
Nov 19, 2012 09:02 AM
Simonak15
Suspension & Brakes
Apr 19, 2006 03:41 AM
mv10s
Aug 16, 2005 11:51 AM
BigBadBuford
Jan 8, 2004 02:00 PM
