99-00 climate control mounting?
Old Mar 4, 2011 | 08:35 PM
Project Dad's Avatar
Default 99-00 climate control mounting?
ok I have searched and searched. I just finished my 96 to 99-00 hvac conversion, but I am not sure how this bezel mounts. Obviously the 96-98 had 2 screws on bottom and 1 behind each button in the corners. I used my 96 dash and changed the center vent. i have yet to see how this mounts with screws. It does pop in but moves around.
Any input? or pictures of you 99-00 with the bezel installed with out a radio?
Old Mar 5, 2011 | 04:43 AM
vanberge's Avatar
Default Re: 99-00 climate control mounting?
I'm going to be swapping out my head unit this weekend actually in my 99
If nobody has any pics or help for you by then I'll get some.
Old Mar 5, 2011 | 02:09 PM
vanberge's Avatar
I hope these pics help....
Basically the front plastic bezel was secured with a few metal clips (most of which I broke off when removing unfortunately).
But there's a somewhat elaborate frame work of metal in there.
The metal framing on the back side of the bezel bolts into place at 4 different spots along the bottom of the framing inside the dash. let me know if it helps!
Old Mar 6, 2011 | 01:05 PM
well I will have to look when I get home. the pictures are not showing here at work.
Also, don't see the need to start a new thread, but I need a picture of the ecu installed. lol sounds dumb but new to honda's and putting the car together from how I bought it. I have search but couldn't find any installed pics
Old Mar 6, 2011 | 10:29 PM
ok. I looked at mine and doesn't have that brace across there. I can't believe that none of the DIY threads brings this up. Especially with the whole security concerns. I guess I will have to fab up some brackets.
still need pics of the ecu mounted please
<ivi>si
Jul 16, 2012 10:29 PM
YumVTEC
Jul 27, 2009 04:40 PM
x916
Nov 26, 2002 04:36 PM
