Can someone please HELP ME with my TIMING on my b18c1
Old Mar 4, 2011 | 10:03 AM
ericnkline's Avatar
Default Can someone please HELP ME with my TIMING on my b18c1
Hey guys, im doing the timing on my 96 b18c1, I made the cams and crank to TDC and then i slipped the timing belt on and it still all lines up, but everytime i tighten the tensioner it takes the crank out of time. am i doing something wrong here? please give me some guidance. thanks!
Old Mar 4, 2011 | 04:03 PM
sayanything's Avatar
Default Re: Can someone please HELP ME with my TIMING on my b18c1
im pretty sure it shouldnt, not too much anyways. are you talking like its 1 milimeter off from the cover mark?
Old Mar 4, 2011 | 07:17 PM
Jewing's Avatar
yeah it usually wont matter if its just a hair off, if it seems like its a whole tooth off then rotate the crank gear just a little past the mark and it should be good
Old Mar 5, 2011 | 03:17 PM
turboacurab20's Avatar
ive had problems with cheap oem replacement timing belts that will line up like a half a tooth off because there where the wrong length so i had to use different timing belt oem honda is the way to go and if its off a tooth after tightening tensioner then turn it a tooth
Old Mar 5, 2011 | 03:18 PM
after tighening the tensioner i also like to slowly turn the motor 2 or 3 complete rotations to make sure everything is good and no valves are hitting pistons
BitterTrigger
Oct 15, 2017 04:26 PM
jdmthug
Aug 22, 2009 07:09 AM
Bob_760
Jan 30, 2008 02:48 PM
P1mpSlap
Jan 7, 2004 10:50 PM
sivik2nr
May 29, 2003 09:30 PM
