Suspension & Brakes Theory, alignment, spring rates....
Need advice on lowering my eg coupe 93
Old Mar 4, 2011 | 12:11 AM
BoostedEK964D's Avatar
Icon2 Need advice on lowering my eg coupe 93
I wanna lower it but want it adjustable. Are ebay springs and coilovers ok or should i get like skunk 2 one for like 280?
These ones are only 53 shipped
http://cgi.ebay.com/ebaymotors/HONDA...ht_4527wt_1242
These r skunk 2 ones.
http://cgi.ebay.com/ebaymotors/SKUNK...ht_2710wt_1165
Old Mar 4, 2011 | 07:37 AM
Default Re: Need advice on lowering my eg coupe 93
ne one?
Old Mar 4, 2011 | 08:32 AM
Rylan's Avatar
Never get eBay coilovers, They are complete garbage. If anything at least get the skunk2 ones.
Old Mar 5, 2011 | 11:11 AM
abs0Lut's Avatar
Go with ground controls!!! So then when you have the money for new shocks you can get Koni's and have one of the most talked about and loved setups. They're only $20-30 more.
Old Mar 7, 2011 | 09:02 PM
whats wrong with ebay ones will they sag? Im on a low budget . Should I just get springs instead ?
Old Mar 8, 2011 | 03:48 AM
Libertariat's Avatar
Ek Forever y0!
If you're low on budget you need to find another hobby.
Using cheap parts on your suspension will cost you more money in the long run due to wearing suspension components and you will want to replace them with better alternatives later on.
If you don't upgrade your shocks when you lower your car, expect them to blow in the near future.
To the poster talking about Ground controls, you have to get koni-specific ground controls for them to work if the OP ever got Konis. You can't just use Ground control sleeves on stock shocks for a few months and upgrade to konis like that.
@BoostedEK: My advice: Be patient, save your money, and do it right.
Is your car even boosted?
Old Mar 8, 2011 | 03:56 AM
MD426's Avatar
There are many things that can go wrong with them. The selves are usually very weak and the threading will just shear off or the lock rings will fail. The spring rate more then likely is unknown and not uniform in most cases. I've had one friend that bought them and went over a pot hole around 60mph and their front passenger side spring snapped. They are usually made in China or some other country that cares nothing about quality control.
Old Mar 8, 2011 | 06:34 AM
Rylan's Avatar
Funny story for you about eBay coilovers.....
Back in 2006 I was a dumb *** and went with the 40$ eBay special coilovers they had on there. I installed them on my 91 Civic Hatch, had the lock right up tight against the height adjustable ring. Nice and tight to, like I couldn't move it with out the cheap *** wrenches that come with them.
After driving on them for 3 weeks the lock ring decided to vibrate loose, and start to spin it's way down. Once the lock ring was spun down by it's self it takes away some of the structural integrity of the height adjustable ring. I didn't notice the lock ring being loose and spun down some until it was to late. Believe it or not, I hit a bump and the height adjusting ring completely skipped the threads. Meaning all of a sudden the car just sagged in the rear.
The sleeves on those cheap coilovers IMO are the most dangerous of the whole setup. They are nothing buy cheap white metal, they aren't strong and they really aren't safe if they aren't strong.
Stupid little story, but that is why I don't like eBay coilovers.
Old Mar 8, 2011 | 07:32 AM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
I have also seen this bottoms of the cheap coilover sleeves actually split and mushroom out as they can't take the weight of the car above it.
And ditto about Koni-specific GC sleeves on Koni shocks.
I'm a big proponent of waiting, saving, and then getting the good stuff and doing it right. I hated driving my car at stock height the first 8 months I owned it, but it paid off by me being able to get Koni shocks which have lasted over 9 years now.
Old Mar 9, 2011 | 08:01 PM
Thanks guys il save up and spend 500-800 on good ones .
Old Mar 9, 2011 | 08:07 PM
yea nuttin special . picked it up for 1750. My DD
Ej1 93 coupe
Evo3 Big 16g turbo ruinning 12psi
Stock Block
Stock Head
Arp Studs
AC PS DLT
greddy s bov
wally 255 fuel pump
ebay front mount
Tuned by swerve automotive
dsm 390cc injectors with resistor box
2step at 4k
2.5 full catback with Test Pipe.
Old Mar 10, 2011 | 02:03 AM
Ek Forever y0!
Old Mar 10, 2011 | 06:47 AM
Rylan's Avatar
Looks like you should be paying attention to the body work before suspension LOL
Nice looking driver side quarter panel. hahah
zuptidi
Aug 21, 2013 05:49 PM
jofat91
Feb 18, 2010 01:03 PM
chb93
Suspension & Brakes
Feb 24, 2009 07:26 PM
Eyedolize
11
Mar 29, 2007 07:42 PM
CivicHP
Suspension & Brakes
Apr 2, 2005 09:08 AM
