When is time for engine rebuild? (based on leakdown test?)
Old Sep 26, 2002 | 07:27 AM
redintegra's Avatar
Default When is time for engine rebuild? (based on leakdown test?)
Did a search, didnt find anything similar
I have 21% and 30% leakdown on cylinder 2 & 3.... 10% or so on the other 2. Is it time for a rebuild? I have 74,000 miles on my Integra LS, 35,000 of it with the JR charger (and I do drive the car hard almost anytime I can.)
Anyone? Thanks.
Old Sep 26, 2002 | 07:45 AM
builthatch's Avatar
MiG-21 superfan
Default Re: When is time for engine rebuild? (redintegra)
yep, rebuild time maybe you should do a regular compression test dry, then one with oil in the damaged cylinders to see if its rings or not...
Old Sep 26, 2002 | 01:58 PM
94gsr's Avatar
I don't have my Helm's handy to double-check, but I believe that more than 12% constitutes a rebuild.
Old Sep 26, 2002 | 02:00 PM
sgT's Avatar
sgT
Default Re: When is time for engine rebuild? (94gsr)
i would do anything more than 10%.
my motors generally see less than 4%
Old Sep 26, 2002 | 03:15 PM
mugenracer's Avatar
Default Re: When is time for engine rebuild? (sgT)
I got my rebuild done when cyl#1 and 4 were reading 18 and 22% and i was going through between 4-6 quarts of oil between 5k services..nuff said!
Old Sep 26, 2002 | 04:20 PM
redintegra's Avatar
Default Re: When is time for engine rebuild? (mugenracer)
I see. Even with my 2 bad cylinders, I dont burn oil believe it or not.
Well, what do you guys replace in a rebuild? Rings, rod bolts, bearings, what else?
How much $$ we talking about?
Old Sep 27, 2002 | 04:17 AM
builthatch's Avatar
MiG-21 superfan
depends on the condition of everything...if its solely rings, then just hone it (assuming the walls are in need of just a hone) and replace the rings, while inspecting everything while your disassembling to re-ring it...inspect the crank journals, inspect the rod bearings, pistons, etc....
Old Sep 27, 2002 | 04:41 AM
Chuck Norris's Avatar
Default Re: When is time for engine rebuild? (builthatch)
Since we are on the topic of rebuilds...I thought I would save some bandwidth and ask you guys. My b18a is in need of a rebuild as well (I fear) and I'm losing oil but do not know where. I have no signs of it in my exhaust, and I parked in the same spot with the car on for 20 minutes...no oil. Where else can I be losing this much oil? Any help is appreciated.
Old Sep 27, 2002 | 10:27 AM
redintegra's Avatar
Default Re: When is time for engine rebuild? (KidNRG)
not sure where but oil does burn to smoke so I don't know if you can "see" it.
My mechanic says he want to do it right and he estimates a rebuild will cost a bit under $3K.... ouch...
Old Sep 27, 2002 | 01:20 PM
tonyxcom's Avatar
I think that is way to high, even if a shop is doing it. But I could be wrong.
Bearings 160 (OEM)
Rings 125(OEM)
Misc Seals, head gasket 200 (OEM)
Honing Only - less then 100 bux.
Bore and hone, less then 200 bux.
Not sure what the labor is for teardown, inspection and assembly though.
If you want another quote on a rebuild, send me an IM. There is a guy in Napa that does all of our machine work and does most machine work for import dealers in the area. He is not a Honda expert, but he is very familiar with them.
Also shoot me an IM and let me know who quoted you 3000.
Acura850.
Feb 11, 2009 12:18 PM
RedRacerCivic
Dec 2, 2003 10:36 PM
crxtreme27
Aug 26, 2003 01:25 PM
VTHokie
Jan 23, 2003 02:08 AM
Dorikamu
Jan 15, 2002 06:04 PM
