requesting info on jdm gsr cams
i have to degree my engine because my crank timing is off from the head and block being resurfaced, so i bought a set of adjustable cam gears. my engine builder is requesting the "tdc lift" in order to time my engine, ive searched only only came up with the lift and duration...
thanks
john
thanks
john
B18C1
Intake
open: 10° before TDC
close: 40° after BDC
valve lift: 10.5 mm
Exhaust
open: 40° before BDC
close: 7° after TDC
valve lift: 9.4 mm
https://honda-tech.com/forums/acura-integra-6/jdm-gsr-cam-specs-578944/
Hope this helps
Intake
valve lift: 10.5 mm
Exhaust
close: 7° after TDC
valve lift: 9.4 mm
Hope this helps
B18C1
Intake
valve lift: 10.5 mm
Exhaust
close: 7° after TDC
valve lift: 9.4 mm
https://honda-tech.com/forums/showthread.php?t=578944
Hope this helps
Intake
valve lift: 10.5 mm
Exhaust
close: 7° after TDC
valve lift: 9.4 mm
Hope this helps
thank you!
