Suspension & Brakes Theory, alignment, spring rates....
Help needed: rack & pinion???
Old Mar 3, 2011 | 05:24 AM
BAY_99DB8LUV's Avatar
Icon2 Help needed: rack & pinion???
He's my specks: Stock 1999 Integra sedan.Running function & form type1 coilovers, front & rear camber kits & function & form LCA's
Sometimeswithin the last year, I've had the following replaced:
Both axles, both ball joints, both bearings. But for some I reason still have some vibration coming from the front while drive at times.... But the key thing is, while the cars parked... There is play within the steering wheel. I can move it side to side & hear like somethings loose. I've been thing possible rack & pinion is bad, but really not sure??? Any thought/ tips would help... Thanks in advance.
Old Mar 3, 2011 | 09:09 AM
Tyson's Avatar
Default Re: Help needed: rack & pinion???
adjust the pinion gear box. loosen the big *** lock nut with a big channel lock plier and turn in the plate with a 12mm nut. drive and readjust until its tight to your liking.
and take off the plastic cover under the dash at the bottom of the steering column and make sure the u joint pinch bolt is tight.
ep3brandon
Aug 28, 2009 02:43 PM
Pvt Fields
Mar 31, 2008 01:59 PM
Rywire
Mar 27, 2008 08:01 AM
SiRay13
Suspension & Brakes
Feb 17, 2006 04:56 PM
Khmi
Mar 21, 2005 11:37 PM
