5 lugs soft brakes help.
So I finally installed my 2000 ITR 5 lug set up in my ek hatch and my friend and I bled it twice; however, the brakes are still soft. What can I do to fix this? What is the problem here?
Thanks.
Thanks.
Anything larger than what you currently have but be aware that some 1" MC's have a different size for the front port. Instead of the 10mmx1.0 I think it's a 12mm. This means a new front line and a reducer to met your prop valve.
You will need to use the jdm ITR 1" mc and booster. If I recall that one has 10mm flare nuts on both ends. The other option is the integra rs 15/16 mc and matching booster. That was a direct bolt on for my eg.
My friend has an usdm itr mc and bb, Does that require that 2 10mm flare nuts? And
If the integra rs is a direct bolt, what about the ls/ gsr? Or the 99-00 civic si, will that work too?
Thanks, this is helping a lot. I want to drive my car already. Lol.
the 99/00 civic Si has ABS i believe, so you'll also have one nut being too big for your non-abs car.
i think in the USA, the '91 EX 4-door sedan has a 15/16 that bolts right up?
ok, so i picked up a 98 integra rs brake booster/ cylinder. its stamped 15/16. i can see that one of the fittings is located on the opposite side, different from my stock ek cylinder. other than modifying the tube or brake pipe (that goes into the cylinder), does everything else bolts right in? plug and play? are the fittings the same size? i know its direct bolt into the eg but is it the same for the ek?
thanks
thanks
joprez
May 7, 2013 02:54 PM
rjp4419
Suspension & Brakes
15
Oct 28, 2010 06:46 AM
chameleon
63
Nov 21, 2003 07:35 AM
