88 CRX dx engine harness swap...
Ok please bare with me Im new to the forum.Ok so I have a 1988 CRX dx with a d15b2 I wanna switch it to mpfi and was wondering if a 1988-1990 Si engine harness would work?I'm going to use the obd0 to obd1 distributor and ecu jumper harness because I have a p28 head I was going to swap on so if anyone could please help thanks.
No You cannot use the engine harness only out of a Si. You need to do the wiring because the DX interior harness will NOT plug into a Si engine harness.
http://hondacrx881.tripod.com/mpfiswap.html
Here is all the information you will need to do the swap.
Also i will Not need the Resistor box because I have a d16z6 head with every thing on it including fuel injectors and I believe there peak and hold not saturated
IHEARTMYHONDA91
Mar 14, 2008 09:55 AM
mr2turbo007
May 28, 2006 05:11 PM
SOHC_Brian
Dec 5, 2003 09:38 AM
