Which ecm should i use with a B20z2 swap in a 1998 civic
Old Mar 2, 2011 | 07:23 PM
TNHOTROD's Avatar
Default Which ecm should i use with a B20z2 swap in a 1998 civic
which ecm should i use in 1998 honda civic 5 speed with a b20z2 swap in it?? thanks
Old Mar 2, 2011 | 07:47 PM
mouab18c1's Avatar
Default Re: Which ecm should i use with a B20z2 swap in a 1998 civic
obd2a ls or convert to obd1 and get a chipped ecu with an ls basemap.
Old Mar 3, 2011 | 05:22 AM
TNHOTROD's Avatar
So the LS ecm i need is from a 96-99 integra i guess?? Any input will be appreciated...
Old Mar 3, 2011 | 07:27 AM
mtber's Avatar
1996-1998 obd2a p75 5 speed ecu. I would personally recommend using an obd2a to obd1 ecu jumper and chipped obd1 p75 engine computer for the b20.
For more information on this subject, check out http://www.phearable.net/tech/efibeginnerguide.html
Old Mar 4, 2011 | 09:48 AM
TNHOTROD's Avatar
i already have a jumper harness on it but kinda wanted the odbII back..this car had the swap in it when i got it and it ran like **** intermittently .. Found that moisture was somehow getting on the ecm and has probably killed it. It will start and run but surge real bad then i can reach over and smack the ecm and it will clear up and run decent.. So my thoughts were if i had to get a ecm for it maybe it would be better with the odbII ecm
Old Feb 10, 2012 | 06:42 PM
nothing_shocking's Avatar
Hate to bring this back from the dead but there's a few things I'd like to clear up...
Is it possible to run an OBD1 P75 ecu, no chip, with a B20Z2 with absolutely no problems and still have the 143 hp and 133 tq?
Will the OBD2a P75 ecu run the B20Z2 with absolutely no problems or will it be trying to find the crank sensor?
What happens with the knock sensor with both of those ecu's?
What is the ABSOLUTELY best ecu set up to use with the B20Z2?
Old Feb 10, 2012 | 07:13 PM
mtber's Avatar
An obd1 p75 stock ecu will run the engine without any major issues.
It may run a little lean in some spots.
Obd2a p75 ecu will look for obd2a sensors such as crank sensor.
Neither ecu looks for a knock sensor.
MastaFlyMason
Aug 23, 2017 02:55 PM
lampshadej1
Engine Management and Tuning
Jun 10, 2010 02:51 PM
93siturbo
Sep 13, 2009 06:02 PM
joshie123
Mar 3, 2009 06:14 AM
slammed00si
Feb 23, 2007 10:04 AM
