92 Civic - Checklist
Old Mar 2, 2011 | 04:56 PM
Rayzorx's Avatar
Default 92 Civic - Checklist
Hi all,
I just purchased a 92 Civic LX/4dr./auto for a project. It has 80K miles and has been sitting for a year, with about 1/8 tank of gas in it. I think I know what to clean up to get it running but I'm open for some other experience tips
After a battery replacement, the motor cranks but it doesn't seem to be getting fuel up front. I'm expecting to have to drain the gas tank, clean or replace the fuel pump and filter. After that, what is the best way to clean the fuel line from front to rear?
I think I need to change out the distributor cap, and rotor, which seemed a bit corroded. Should I change the spark igniter as well?
Also, I noticed oil all over at least one spark plug when I pulled to look for spark, so I'll replace the plugs too. I'm guessing that this is due to dried out o-rings in the tube letting oil by? I plan to replace them and the valve cover gasket.
Is there anything else I should look for?
Thanks!
Ray
coco718
33
Oct 4, 2011 12:09 PM
G2_Fella
Aug 15, 2009 11:24 AM
spens 91 Ef
May 28, 2009 05:56 PM
MI4$DC5
Oct 20, 2005 07:44 AM
Al Bundy
Oct 15, 2002 04:46 PM
