DA GSR partout, B-series performance parts, exhaust, cams, type R, B16 B18, trans
Old Mar 2, 2011 | 04:38 PM
heritage36's Avatar
Default DA GSR partout, B-series performance parts, exhaust, cams, type R, B16 B18, trans
So unfortunately my 92 Integra GSR was brutally hit and run by someone last night in the driver rear corner and is not really fixable, so I am parting it out and selling some of the things I imagine people would be interested in and many other parts I was going to put on it eventually....
B17 motor, harness, ECU in great shape ran strong, recently tested over 150+ compression on all cylinders. Has newer platinum NGK plugs, newer injectors, new distributor coil and ignitor, NGK ignition wires, new cap and rotor, many other new things, taken good care of, taking offers on it since it is hard to price a B17 since you never see them for sale.-GONE
S1 cable transmission, stock, in great shape, shifted perfect, new axle seals, fluid changed often-$350obo
DA GSR cluster with cf bezel and red LED bulbs, looks nice at night-$100-sold
DA OEM moonroof visor with oem hardware still-$75-GONE
DA armrest with EK cover (longer)-$50-GONE
HKS hi-power catback exhaust, used for a few months-$175-GONE
Magnaflow converter, used a few months-$50-GONE
ebay cold air intake 1-piece-$25-GONE
DA ABS delete kit, prop valve and lines to go in place of DA ABS modulator/lines-$75
Anything else of interest, feel free to ask, all is good other than the body really and anything in the driver rear corner
Other B-series stuff....
J1 cable transmission with quaife LSD and LS 5th gear, small crack in case but doesn't effect operation or anything really, includes a clutch kit for 90-91 DA and think works with some others too that is new-$950
Skunk2 stage 1 pro series cams for B-series-$350-GONE
RMF replica header, new in box-$150-GONE
Test pipe, telescoping and adjustable, new still-$50-GONE
type R knock off pistons, would have to check the brand, but new in box with rings and wrist pins-$75-GONE
type R cylinder head, no cams or hardware that mounts the cams, but full valve train and dual springs, etc. Have a set of GSR cams I will include if wanted-$150-GONE
type R intake manifold with 65mm rc tb and thermal gasket-$100---SOLD!!!
B17 OEM rods, used-$50
JDM Gathers amplifier-$50
DA driver side innovative mount-$30
Energy suspension motor mount insert kit, new-$15
PR3 ECU redone by Locash racing in arizona, no rev limit, stronger fuel map, few other changes-$75
HKS circle earth grounding kit, universal, new in box-$100
DA integra OEM Acura Service manuals, basically new-$75
ACT cable B-series street clutch with pressure plate, used for a few months-$75-GONE
9lb chromoly flywheel for B-series cable transmissions-$75-GONE
Two B-series VTEC valve covers, one still original with only very slight paint chipping, other was painted black glossy by someone previously-$30 each-sold
pics of car and some things...
http://s900.photobucket.com/albums/ac204/heritage36/
You can make me an offer on anything, but I think most of these prices are pretty reasonable.
Will try to list other things as I think of them, because there is a lot. Located in Milwaukee. Call/text 262 993-1514 for pics questions, etc. Thanks!
Old Mar 3, 2011 | 04:06 AM
heritage36's Avatar
Default Re: DA GSR partout, B-series performance parts, exhaust, cams, type R, B16 B18, trans
intake manifold sold!
Old Mar 3, 2011 | 04:18 AM
hrs-parker's Avatar
pics of rmf rep header
Old Mar 3, 2011 | 04:32 AM
hardcore97's Avatar
price shipped on both valve covers to 65066
Old Mar 3, 2011 | 08:24 AM
90LSpimpin's Avatar
Bump for great prices!
Old Mar 3, 2011 | 08:46 AM
heritage36's Avatar
Thanks for the bump, would have to get pics later, but the header is new, so I am not sure what there would be to see.
Old Mar 3, 2011 | 08:48 AM
ehybeech95eg's Avatar
damn that sucks....glws mike
Old Mar 3, 2011 | 11:32 AM
jaymua's Avatar
Where did you find a generic strut bar that fit with ABS?
Old Mar 3, 2011 | 12:20 PM
heritage36's Avatar
ebay
Old Mar 3, 2011 | 10:31 PM
90LSpimpin's Avatar
pm'd
Old Mar 3, 2011 | 10:50 PM
dohc_sedan's Avatar
you have a pm..... contact me asap. pm back or text 8155416568
Old Mar 4, 2011 | 07:44 AM
heritage36's Avatar
Updated, sorry but have a pending deal trading a bunch of this stuff for a car.
Project_EK
Northeast (Sales)
Sep 5, 2011 08:58 AM
haas480
Jun 8, 2009 08:06 AM
R.and.Y
Apr 9, 2009 12:13 AM
singlecamcrx
Dec 2, 2004 03:56 PM
