Rear lower control arm length vs. aftermarket
Old Mar 2, 2011 | 04:14 PM
Farlander's Avatar
Default Rear lower control arm length vs. aftermarket
My rear tie bars (rear rear control arms, or rear lower control arms, NOT trailing arms) are aftermarket, and at my shop I cannot get the rear toe to come in far enough. The toe adjuster slide is maxed out, and before I go big bucks to replace with factory, I want to know if there's any difference in overall length between the two. If the stock bars are longer, than it will help bring my toe in. The car had a lowering kit, so maybe that's why the shorter 'red' bars were used? I've actually drilled the adjuster slides too and widened them slightly which helped a lot but still not perfect. I'd rather not spend big bucks on a toe adjust kit. Thanks
Old Mar 2, 2011 | 04:35 PM
grumblemarc's Avatar
The Grumpiest
Default Re: Rear lower control arm length vs. aftermarket
Define aftermarket. What brands are we talking about?
Old Mar 2, 2011 | 05:04 PM
Farlander's Avatar
I have no idea because they were on the car when I bought it. They look like this
Old Mar 2, 2011 | 05:13 PM
The Grumpiest
How low is it? Is there a camber kit installed? Maybe you can try the old washer trick.
http://www.ej8squad.com/thread-5157.html
Untouchable13
Honda Civic (2001 - 2005)
Jul 12, 2009 10:36 PM
water
Mar 6, 2004 08:40 AM
ESCALVANTE
11
Mar 12, 2002 06:17 PM
