S2000 interchangeable parts?
what about the rods and maybe not much has to be done to the pistons and ive heard of s2000 valve springs being used on a second gen si sooo
FYI, the rod length and bore is different between the F20A and F20C. I'm also pretty sure the main journals are different sizes so the crank won't work either. Next time, spend some time searching because all of this is information is available with a search.
the are two totally different engines....they can't even be compared...i remember when i found out honda was using the engine code F20C for the s2000, i thought to myself "i bet every accord guy is going to think they can take parts from this motor"...and i swear we told you this in your other thread
main journals are different diameters (the F20/22C's use 55mm mains)
rod bearing journals are the same at 50mm (most honda motors use 50mm for the rods right?)
deck heights are different
So in order to make it work, you would have to machine the wrist pins to match the piston/rod you're planning to use, as well as make sure the piston doesn't stick out of the hole too much.
then for the head, probably nothing to use from the s2000 head.
finally somebody telling me what i should do and then can do
im not an expert like you guys so can an expert tell me why the valves and valve springs wouldnt work, there size difference, and what i could do to make them fit
are you stupid? at least three different people have told you nothing is "interchangeable" between those motors...theres nothing you can do to make anything fit man...give it up
holly crap op do u ave a mental disability? nothing will interchange and the money you would have to spend to make something interchange u would be better off buying a h22 swap for ur accord
I bought my car and it has RC 650cc injectors. I was looking for some stock injectors. Does anyone know what kind of injectors I can get that will fit? New one are like $170 from the honda dealership. Suggestions?
IIRC the stock injectors are mid 300's... 360cc maybe?
MrJDM_
Jul 25, 2013 10:54 AM
2001present, 55mm, accord, body, engine, hardtop, honda, interchangable, interchangeable, journal, main, part, parts, s2000, silverstone, size, springs, valve
