*Help* 96 GSR still won't start
Old Mar 2, 2011 | 05:38 AM
::ek-4::'s Avatar
Icon6 *Help* 96 GSR still won't start
Just bought a 96 GSR with 116k miles on it like 2 months a go. Car ran fine when I bought it. I haven't been able to drive it for almost it two weeks now. :-( I was driving and the tach just died. 2 minutes later the car just puttered and stalled out. It wouldn't take a jump. Towed it home and have since changed the spark plugs, alternator, and distributor. Just changed the battery today and the car started but then died after 2 seconds. Will crank but won't start anymore. Maintenance required light flashes 9 times after I try and start it. But no Check Engine lights. Engine is stock except for a CAI. Starting to get frustrated. Any advice??
Old Mar 2, 2011 | 06:20 AM
::ek-4::'s Avatar
Default Re: *Help* 96 GSR still won't start
I smell fuel when I try and start it, so I know it is not a fuel issue.
Old Mar 2, 2011 | 07:32 AM
weavertime1's Avatar
Are you sure that the dizzy you replaced it with is good? Sounds like a distributor issue to me, but you may want to check the ecu and main relay as well.
Old Mar 2, 2011 | 07:59 AM
::ek-4::'s Avatar
There is an oil leak coming from the head gasket, I hope my compression is still good. It should at least start though.
Dizzy has only 2000, miles on it and came out of running car. I'll check the ecu and main relay when I get home from work. Thanks!
Old Mar 2, 2011 | 10:26 AM
1998GsRIntegra's Avatar
Sounds like the igniter as it feeds the tach. I would also check your ecu. Make sure it is good.
Old Mar 2, 2011 | 01:45 PM
Just to add some info...I have literally taken a known good dizzy from one car, and installed it in another car, and had it go bad...I know it seems coincedental, but I have seen it more than once. As stated above, it does sound like an internal distributor issue because of the tach problem that occurred first.
Old Mar 2, 2011 | 04:19 PM
el crapitan's Avatar
check for spark. if none exists,
test for power at the distributor connector, pin for the ignitor. if you have power at the pin, the distributor is likely defective
Old Mar 3, 2011 | 07:43 AM
::ek-4::'s Avatar
I work two full time jobs so I barely have time or daylight to work on my car. Thanks for all your input. I pulled the spark plugs are they are black. They smell of gasoline, doesn't look like oil. Having my friend come by and do a compression test. Borrowing another friend's ECU and dizzy to see if that solves the problem.
Old Mar 3, 2011 | 04:49 PM
fonkernuckle's Avatar
The fact that you say you smell fuel reminds me of my car last week, ignitor went bad(according to the autozone check machine) and my timing belt skipped a tooth,check your timing belt to see if its still on the timing marks at tdc (cams lined up and crank mark on oil pump mark) sounds to me as if it skipped a tooth and check your coil and ignitor, no flaming necessary just suggesting.
Old Mar 3, 2011 | 05:01 PM
check spark yet? clean the plug you test good with some emery cloth. it may be fouled
Old Mar 4, 2011 | 10:47 PM
turboacurab20's Avatar
id check the easy stuff first put new plugs in it and then check to see if battery terminals are tight and put some gas in it just in case gauge broke / then check for spark and i usually disconnect the fuel line and turn key on to see if fuel sprays out for fuel pressure
Old Mar 5, 2011 | 04:16 AM
flaco2007's Avatar
You need to check for spark. if no spark check the coil on the dizzy. if that good. check the timming belt. thats all you need to do.
Old Mar 7, 2011 | 02:36 PM
::ek-4::'s Avatar
I have no spark. Ordering new coil today.
Old Jun 22, 2011 | 12:14 PM
JDMFreaK414's Avatar
My Car Has Same Problem Basically I Need Help! I Got a 96 Gsr Originally everything.. I was about to go threw a puddle so i slow down before the puddle the car just everything died and turned off. and i rolled threw the puddle nothing go real wet. I Went to Go restart the car it wont turn over but it tries. it has a check engine light. and i checked for spark with a allen wrench and it had none so im thinking coil? I turn the car to ACC and i hear the fuel pump kick in. and wen i try to start it the battery light flashes?
HELP ME PLEASE
Old Jun 22, 2011 | 07:23 PM
open the oil filler cap and look inside while someone cranks the engine. see if the cams are turning
Old Jun 23, 2011 | 10:03 AM
they turn?
Old Jun 23, 2011 | 10:11 AM
hondaluver19's Avatar
HELP ME PLEASE
You don't have a CAI do you? If so, make sure you don't have water sitting on top of the pistons. Check this before you try starting your car again.
Old Jun 24, 2011 | 12:33 AM
andrewxxcarlson's Avatar
<333333 Hahaha.
Old Jul 6, 2011 | 01:00 PM
::ek-4::'s Avatar
OP, car fixed. Dizzy took a dump. car came with 2 month old Advanced Auto Parts dizzy and its garbage.
/thread
ToolJunkie21
Jun 22, 2016 06:25 PM
Steveojonez2112
Jul 24, 2012 03:55 PM
cuongnextdoor
Dec 19, 2011 05:41 PM
::ek-4::
Mar 2, 2011 06:26 AM
b18b-HB
Feb 10, 2003 06:03 AM
