strut and shock assembly?
Old Mar 1, 2011 | 06:48 PM
karrar55's Avatar
Default strut and shock assembly?
I wanna lower my 94 honda accord and i found the struts and adjustable springs and im wondering if i can use the same strut mounts from the old struts?? and any tips would be appreciated !! thanks!
Old Mar 2, 2011 | 12:05 AM
cyotani's Avatar
Default Re: strut and shock assembly?
just lowered by 94 accord using these two guides. It was pretty simple. took me about 4 hours but if I had to do it again it would be under 2. only tricky part I had was finding the right angle to slide the rear strut out from the fender. Yes you reuse the same top hats but you will need a spring compressor to take them off your stock struts and install them on the aftermarket ones. here are the two sources I used. let me know if you have any problems. good luck!
https://honda-tech.com/forums/honda-accord-1990-2002-2/5th-gen-accord-bilstein-shock-install-how-lots-pics-2188254/
the same guy made a youtube video
http://www.youtube.com/watch?v=HAAADWVk1nQ
http://www.youtube.com/watch?v=_tTwAkUgt7g
Old Mar 2, 2011 | 04:46 AM
karrar55's Avatar
Hey thanks for the reply! One more thing what type of shocks and struts did u use cause im thinkn of getting seperate adjustable springs and struts
Old Mar 2, 2011 | 05:05 AM
djkurious's Avatar
How low will you be lowering your car?
Old Mar 2, 2011 | 08:43 AM
karrar55's Avatar
I wanna lower between 2 to 4 inches
Old Mar 2, 2011 | 08:52 AM
cyotani's Avatar
Im on tein full coilovers which i found used for a good price. It depend how much you want to lower your car. tokico blues seem to be the most common strut for any drop up to 2 inches ($300 for a set). For a bigger drop and if you want damper adjustment struts then most people would recommend either tokico illumina (about $400) but Koni Yellow seems to be by far the favorite (over $500). for adjustable ride height springs the only ones I've heard of that are highly recommended are ground control coilover sleeves which can be ordered in custom springs rates. If you dont want ride height adjustment tein s-tech and eibach pro kits are common springs for a 1.5-2 inch drop. If price is an issues keep checking the sell forums and find a used set. I got used Tokico blues for sell for $150 if your in the LA area.
Old Mar 2, 2011 | 08:54 AM
cyotani's Avatar
Im pretty sure you dont wanna lower your car 4 inches. The thing would not be practical as a daily driver. you would scrape on every driveway. Anything past 3 is pushing it.
Old Mar 3, 2011 | 09:45 AM
33steviebix's Avatar
i had my 98 4dr on kyb gr-2 struts and tein s-tech springs, lowering it 2" all around. everything mounted to stock, no problems, and ended up with a smooth, firmer ride with the looks to match. that was with 18" wheels and 225/45's.... i always wanted it a bit lower though. but dont go 4", most coilovers wont even drop that low.
stepheneb
May 31, 2014 06:57 PM
IP RACING
May 26, 2007 08:00 AM
94HondaAccordEX
Mar 26, 2006 10:21 AM
eymnewdc4
Jul 31, 2005 07:52 PM
94eg4
May 3, 2004 06:44 AM
