EJ B-series Axle, Suspension Issue???
Old Mar 1, 2011 | 06:30 PM
BoOsTeD_eG6's Avatar
Default EJ B-series Axle, Suspension Issue???
I have a 94 EJ coupe, LS Vtec with hydro GSR, hasport mounts and advance auto parts GSP new axles. The issue I'm having is since the swap went in, roughly 12000 miles ago, I have had axle vibration during acceleration. When I installed the axle I had to stretch the inner boot to be able to get the axle nut started. Once tightened the inner boot looks poor to say the least. The car has OE springs and KYB OE replacement struts, but has negative camber on the passenger side. Visual inspection and countless people haven't been able to give me any answers as to what could cause this.
My best guess is the car was wrecked, but that leaves several questions. Why would the axle be too short if upper or lower control arm was bent? Also, why would it have negative camber if lower control arm was bent? Is it possible that something stretched? I'm drawing a blank.
Thanks in advance for any and all help.
Old Mar 1, 2011 | 08:10 PM
HandleTech's Avatar
Default Re: EJ B-series Axle, Suspension Issue???
wrong axle...try another one..
off an ls integra
Old Mar 7, 2011 | 07:35 PM
HandleTech's Avatar
off an ls integra
http://www.youtube.com/watch?v=SDTZ7iX4vTQ
Old Mar 7, 2011 | 08:09 PM
94EG8's Avatar
Seagull Management
off an ls integra
Hydro B-series are all the same (except JDM '98+ ITR) aftermarket axles frequently vibrate on acceleration, sometimes you have to exchange them numerous times, or bite the bullet and buy an OEM one.
'00_GSR/R
Sep 29, 2010 07:32 AM
92b20teg
Mar 3, 2009 05:28 PM
S13 slide
Jun 23, 2004 06:02 PM
94rsvtec
Mar 10, 2004 12:28 PM
shorty0o29
Feb 24, 2004 09:31 PM
