Suspension & Brakes Theory, alignment, spring rates....
Use adapter plates for Skunk2 coilovers and Koni yellows!
Old Mar 1, 2011 | 03:42 PM
sde780's Avatar
Default Use adapter plates for Skunk2 coilovers and Koni yellows!
I had an issue with a broken perch on my Koni yellow with skunk2 coilovers...I'm driving and hit a decent pothole and heard something rubbing. As I hit a dip in the road I suddenly hear my tire being eaten up by my fender. Limped it back home and found that my Koni perch's inside machined groove was bent up and the circlip was no longer a circle. Called Koni and talked to someone on the tech team.
Mr. Paul on the tech team blamed it on my skunk2 coilovers. CRXLee on here (Lee Grimes) even posted that they see accords and Preludes with this problem due to the car's weight, and they usually send out new circlips and perches. But nope, since I don't have original receipt and I didn't buy them new they can't do anything about it.
to Koni from me
Here's the post from CRXLee circa 2005 when someone else had the same issue...
Originally Posted by CRX Lee
Give me a call at the Koni office at 859-586-4100 ext 316 and we can discuss it and get some new rings and a perch out to you.
Normally we only see this kind of thing on cars with ill fitting coil-over sleeves (thus all the importance to use proper circlip capturing GC or Koni sleeves). Obviously you do not have a coil-over system on the car, this is a very rare occurance that we see only a couple of times per year and then on Preludes or Accords (the heaviest models) that are pretty well lowered and take a mighty whack from the road. Essentially hit causes your spring into coil bind going solid and then the remaining force of the impact extrudes the spring perch down over the circlip. The circlip itself did not fail, it was destroyed as a symptom of the impact. A new circlip is needed and a fresh perch is a good idea as well just to make sure everything is fresh.
Call me and we'll get you back going.
Anyone else have issues with the perch failing? I'm not the only person this has happened to and the "customer service" I received was pretty bad, the guy didn't offer to sell me a new perch, didn't try to resolve anything. After I explained everything he just said I ran too high of a spring rate and it's my fault, and that Koni won't cover anything because I'm not the original purchaser of these shocks. I also called CRXLee and left a message, didn't hear back from him yet
Old Mar 1, 2011 | 04:15 PM
TunerN00b's Avatar
Default Re: Koni's horrible customer service
I believe that the warranty is only for the original purchaser, so expecting them to warranty used parts is, more or less, asking for a favor.
You had the Koni spring perch on top of the circlip, and the sleeve on top of that? I think that is what Koni says to never do. You should be running the sleeve directly on the circlip, and the sleeve should correctly capture the circlip to prevent it from deforming like that. The sleeve doesn't place the force on the same location that a spring on the perch would, which is what leads to failure.
Of course, all of this is from memory, and my memory sucks, so I could be wrong.
Old Mar 1, 2011 | 04:42 PM
racebum's Avatar
A: you can't use skunk2 sleeves without adapters on koni sports, only the koni str.t
B: the warranty is only for the original buyer
Old Mar 1, 2011 | 05:06 PM
sde780's Avatar
Yes I have the perch on the circlip, then sleeves over that. Sleeve will not catch on the circlip directly, I think that's only on Koni-specific GC sleeves? My skunk2 sleeves don't have the machined groove to fit it.
Racebum you mean like these?
https://honda-tech.com/forums/suspension-brakes-54/not-write-up-write-up-skunk2-konis-2592526/
A guy in there said he used the adapters and they failed as well. And talked to the same guy as me, "Paul" who offered no help
I understand the warranty thing, but I thought this was a design flaw as a quick google search found several other people with this problem, and even crxlee admitted that he's seen a few each year which means I'm not the only person this has happened to
Old Mar 1, 2011 | 05:29 PM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
I don't see where Koni is at fault at all here. The lifetime warranty is for the original purchaser only, and you should never use coilover sleeves with the OE-style spring perches on Koni shocks.
I received my Koni shocks with one broken adjuster tab, and they immediately shipped me a new shock to replace it.
Koni North America gets a big from me. Don't knock their customer service when you really have no claim with them to begin with.
Old Mar 1, 2011 | 05:41 PM
TunerN00b's Avatar
And that could be a cause of failure.
The Koni supplied spring perch needs to have any force from the spring applied around the edge, where a stock spring would sit, to force the circlip down and inward.
A threaded sleeve on the perch usually places the force on the center, directly above the circlip, putting all of the force in a direct downward direction.
GC Koni specific sleeves do catch the circlip, yes.
Koni also sells sleeves that go directly over the circlip. They use 2.25" springs though, and use an adapter for 2.5" springs.
Skunk2 sleeves require their adapter for proper use on a Koni Sport shock. Notice that the linked thread specifically states that failure to use the adapter will void the Koni warranty (not sure how true that actually is, but it supports my point).
If Koni is saying you misused the part, you might need to accept that. You can always try to buy new circlips and then sell the shocks.
Anyway, please don't think I'm trying to place any blame here, or give any input on "right and wrong". I'm trying to throw out information in case it is useful.
Old Mar 1, 2011 | 06:57 PM
sde780's Avatar
Thanks for the info, I had no idea about the adapter kit until I made this thread. The person however was talking about my skunk2 coilovers having too stiff spring rates, which I didn't think was the reason for this failure because others have ran these on Preludes with Koni yellows with no issues.
I'll be buying a set of those adapter plates in that case, not Koni's fault here. My apologies to Koni, I'm editing the thread title so anyone searching doesn't get the wrong idea
Old Mar 1, 2011 | 10:18 PM
racebum's Avatar
Default Re: Use adapter plates for Skunk2 coilovers and Koni yellows!
sounds like you have it figured out and that's basically it. the koni str.t can use standard slip overs but the sports can not. the sport is really designed for use with either standard springs or the special ground controls made for them. even with the adapters the diameter is off when using the skunk2 which doesn't seem like the most secure way to run a setup
Old Mar 2, 2011 | 06:39 AM
90_EX_Civic's Avatar
did not know that.... hmm... maybe i should get a set of gc collars now?
PINKFIFFTY
Suspension & Brakes
Mar 30, 2017 01:56 AM
bmoua
Suspension & Brakes
Jan 30, 2008 03:14 PM
ludekid4323
Suspension & Brakes
Dec 31, 2006 06:47 PM
singlecamcrx
Dec 6, 2004 08:47 PM
paulyman
Jun 25, 2002 06:07 PM
