FS/FT..Civic/Integra/OEM&More
Old Feb 28, 2011 | 11:45 PM
SlaminSohCivic's Avatar
Icon3 FS/FT..Civic/Integra/OEM&More
Hey whats goin On...I finally got a list of Almost Everything ive got as Requested....I know alot of People Need Oem Parts to..I Pretty Much Sold All my Turbo &Aftermarket Parts...So Heres What Ive got &What ill trade for...I Know Moneys tight for everyone so if u need somethin over $75.00 Ill take some trades to Knock off some Cash so when u hit me up Tell me what you got....Zack 724-984-6442
NOTE: I HAVE NO PROBLEM TAKING PICTURE OF PART WITH MY NAME OR W.E U WANT ME TO WRITE ON A NOTE TO SEE ITS LEGIT....DONT HAVE PAYPAL RIGHT NOW BUT IM WORKIN ON IT...POST OFICE MONEY ORDER
Im Looking to Trade for
Crower 402-T Cams for B18A/B
Tail 38mm External Wastegate
Rear Disc Swap Off Civic..Complete Nothin over $125.00
Eagle H-Beam Rods for B18A/B OR B20
PRICES ARE OBO BUT PRETTY FIRM
ECUS
OBD0 ZDYNE B16A CHIPPED ECU...B16A 10 PSI T3/T4 TURBO....Got to send to Comp to get retuned.....$80.00 Obo
OBD1 P75 B18B1 ECU....Stock...$85.00 OBO
OBD1 P28 D16Z6 ECU...STOCK...$95.00 OBO
OBD1 P28 D16Z6 ECU...CHIPPED...Wit Any Basemap u like...$135.00 OBO
OBD1 P0B F22B2 ECU...STOCK.....$55.00 OBO
OBD2 P2E D16Y7 ECU...STOCK...$50.00 OBO AUTO
INTAKE MANIFOLDS
D16A6 PGMFI IntaKE MANIFOLD...OBD0....Complete/w Red Injector Clips...$50.00 Obo
B16A JDM OBD0 Intake Manifold...Semi Bare...No Fuel Rail/Injectoers...$50.00
B16A JDM OBD0 Intake Manifold...Complete.....$85.00 Obo......Can Convert Injectors to B18c1 Injectors for Extra $15.00 then it will work on obd1 car
B18A1 OBD1 INTAKE MANIFOLD...BARE...$30.00 OBO
B18A1 OBD0 INTAKE MANIFOLD...BARE...$27.00 OBO
DISTRIBUTORS
D15B7 OBD1 DISTRIBUTOR 61k Miles....$60.00 Obo
D16Z6 OBD1 DISTRIBUTOR 90K Miles...$75.00 Obo
D16Z6 OBD1 DISTRIBUTOR.....FOR PARTS...$40.00 OBO
ENGINE PARTS&STUFF
D16Y8 Pistons&RODS....87 K Miles...In great shape Needs cleaned...$45.00 Obo
B18A1 Pistons&Rods...61k Miles...Mint....$60.00 Obo
D16Y7,8 OBD2 Altinator...Great condition...54k Miles...$50.00 Obo
D16Z6 OBD1 Altinator...Works Good...75k Miles...$40.00 Obo...Needs Pulley
B18B1 AUTO Half Shaft...Good Condition...$45.00 Obo
B18A1 Valve Pan Cover...Sand Blasted..Bare Aluminum..Cut for cam Gears...$45.00 Obo
B16A JDM HEAD Fresh Out Machine Shop Was Resuraced&Cleaned &Check Because Head Dropped Valve...Note is Some Damage to chambers...But i had machine shop make sure it wasnt ganna effect anything or leak compression..Everything checks out good....Needs 5 Valves Replaced.....HEAD INCLUDES....All Valves Execpt for 5.....8 Duel Valve Springs...8 Single Valve Springs...LMAS...Cam Caps...B16A2 JDM SIR II CAMS/GEARS....Keepers...Retainers...New Valve Seals.....DOES NOT INCLUDE Valve Cover,Distributor,Vtec Solenoid,,Intake Manifold,
PRICE IS $235.00 OBO
D16Y7 Non Vtec Cam...Good Shape $30.00 Obo
88-91 Civic/CRX AIRTEX Fuel Pump....Still in Box...i Put it in my 92 civIC an seen it was bigger an didnt mount...Retail On Ebay Whch is cheap is $175.00 My Price $90.00 Still In Box
(2) D16Z6 Fuel Rails...Can Also Be used on D15B7....$20.00 Obo
D16Y7/8 Engine Mount Bracket &Pillow Mount Ges to Frame...Came off my Wrecked EK...I replaced this Mount 20k Miles Before Wreck...No Rips...Includes Both Bracked and Pillow Mount to Frame...$55.00 For Both Obo
D15B7/Z6 Driver Engine Mount Bracket&Mount...Not Aluminum One...Bolts are same..its same just not at pretty...$40.00 Obo
92-95 Civic Stock Intake Tube&Box...Ok Filter Included...$35.00 Obo
94 Integra Stock Intake Tube &Air Box $45.00 3" Rubber Tube Great For Civics
90 Integra Injector Resistor Box...Perfect For Putting DSM 450cc Injectors in new civics u need this box...$22.50 Obo
90-91 B18B16 Cable Tranny Speed SENSOR....uses cable..works great....$35.00 Obo
H22/F22B OIL Pan...Dentd a lil...$35.00 Obo
92-95 Civic (2) Cruise Control Units...$35.00 Each $45.00 wit cable
D16Z6 STARTER..WORKS GREAT..Just one Bolt tabb broke off but one bolt held fine for me...$20.00 Obo
92-95 Civic EX Stock Exhaust From Cat to Axle....Rear Section Not included...$45.00 Obo
B18/B16 Hydro XTD Stage 4 Pressure PLate 4,000 Miles...No cracks or groves...$45.00 obo
B18C1 OEM FLYWHEEL 81K mILES....B18C1 OEM REPLACEMENT Pressure Plate...6k Miles..Perfect....$75.00 Both OBO
D15B2 OEM Replacement...BRAND NEW....Just set in my basement a lil while tiny bit of surface rust.nothin big.....$40.00 obo
SUSPENION
(4) 92-00 Civic Stock Struts&Springs...Struts were Replaced 21k Before i put Tokicos on my car.....$120.00 All 4 Complete Set
(4) 94 Integra Fronts&Rears Stock Struts and Springs....67k Miles....$100.00 Obo
(2)92-00 Civic Stock Front Struts...Includes Top hats&Forks..No Springs...50k Miles....$45.00 Both Obo
(1) 95 Integra GSR ReAR Strut/Spring...84k Miles...$25.00 Obo
SKUNK 2 COILOVERS....9K Miles...Aluminum Keepers are Perfect....Paints Chipped ON Coilovers but u can see there Skunk 2s....Retail $275.99....My Price $165.00 Obo
(3)92-95 Civic Front Upper Control Arms..Stock...Ball Joints are good...But Need New Ball Joint Rubbers...2 Include the mounts in back....$12.00 Each 0bo
(1) 88-91 Civic Driver Side Upper Control Arm...Stock...Good Ball Joint...No Rear Mounts...$10.00 Obo
94 Integra LS Front Sway Bar/w Stock End Links...Need New Bushings...$40.00 Obo
92-95 Civic EX Brake Master/Booster Cyliner...Great Shape..Has 1 Tiny Dent....Bigger an better stoping power then None EX 1 Size down from Integras...$45.00 Obo Includes Resisvor
94 Integra GSR Steering Colum..ABS...No Steering wheel or Air Bag...Has Ignition/w Key...might need new turn signal stick...$100.00 obo
94 Integra GSR Power Steering Rack Pinion....No Inner or Outer Tie Rods...$60.00 Obo
92-95 Civic FULL Power Steering Set up,, Pump,Lines from rack,Cooler,Bracket,Belt,Resisvor,Everything but Rack.....$75.00
92-95 Civic EX Passenger Side Hub....Good Rotor/Caliper...Note That EX Hubs DO NOT FIT 13" Wheels&bigger rotors and pad then reg civic...Good wheel bearing$55.00 Obo
BODY /EXTERIOR
94 INTEGRA COUPE GREEN resr bumper....Great Shape..Got a couple tiny screw holes on top...$40.00 Obo
92-95 Civic Coupe Driver Side Fender...Needs Some Work....Not Dented.....$25.00 obo
91 Civic Front Bumper....Not the Best but not cracked or broke $30.00 Obo
92-95 Civic Ex Front Bumper OEM Black..Great Shape...Jst dude cut both lil corner Tabbs dunno why....$45.00 Obo
92-95 Civic Coupe F1 Fiber Glass Fenders Good Shape...Might nEED WET Sanded Etc...But Nice...Retail $185.00 Obo...$95.00 Both Obo
92-95 Civic Hatch Only....Polyurthane....Side Skirt&Rear Bumper Pieces...Not These Go Over you Stocks....Will Not break....$70.00 Obo
92-95 Civic EX Passenger Side Door Burnt Orange...All power...Shaved Door Moldings...Might havesmall dings...No door panal...Or Door Handle...$55.00 Obo
92-95 Civic EX Coupe Trunk Lid...Mint Burnt Orange....EX ONLY HAS LIP....$50.00 Obo
96-00 Civic 4 Door Trunk Lid Flat Black...GREAT SHAPE....No taillights...$45.00 Obo
88-91 Civic Door Panals Not sure Of year..But Black&Grey...Good Shape...$40.00 BOTH
88 CRX SI 3 pc Taillights...Mint...Hard to find..Im pretty sure they got the harness...$90.00
96-00 Civic 4 Door Taillights..Minty...NOT 00 SI...$45.00 OBO
96-00 CIVIC Coupe Taillights..Mint...NOT 00 SI....$55.00 OBO
94 Integra GSR Coupe CARBON FIBER FAKE CLEAR TAILS...small Crack on corner of one...Doesnt leak$30.00 Obo
96-00 Civic Driver Side Head Light..Good shape...Lil Faded needs wet sanded $40.00 Obo
92-95 Civic (2) Drivier Head lights Good Glass One has good Plastic 1 broke tabb....(2) Passenger side lights 1 good plastic...$20.00 Each
92-95 Civic Driver Side Manuel Mirrior...$20.00 Obo
94-01 INTEGRA LS 14" HUB CAPS...BLACK $35.00 ALL 4
CIVIC/INTEGRA WHIPER ARMS $10.00 EACJ
94 INTEGRA COUPE REA WIPER MOTOR AN ARM $35.00 obo
INTERIOR....ETC...
PIO 760 WATT 2 CHL AMP ...$55.00 OBO
DELSOL Si 5 Speed Cluster 202k Miles...Mint...$50.00 Obo
CRX SI BLACK CENTER CONSOLE...Just back piece over e brake...$10.00 Obo
96-01 tan Glove Box mint,..$22.00 Obo
96-01 Tan Center Console...Fulll thing...$40.00
92-95 Civic Black Cluster Cover../w Clock AN Vents&4 way switch...Hard to find a mint one..$45.00 Obo
94 Integra GSR BLACK Passenger Side Power Door Panal...$40.00 Obo
92-95 Civic Black Passenger Side Manuel Door Panal...$25.00
96-01 Tan Bare..No metail..no air bag..cluster harnes...shell is mint $25.00 obo
Delsol SI 2 BLACK CENTER VENTS...$10.00 OBO
94 INTEGRA gGSR Passenger side air bag..Great Shape...$50.00 OBO
I HAVE TONS OF MISC INTERIOR PIECES HIT ME UP
THATS ALL IM PUTTING UP FOR NOW
Old Mar 2, 2011 | 06:50 PM
Default Re: FS/FT..Civic/Integra/OEM&More
bump
Old Mar 17, 2011 | 06:23 PM
BUMP ILLL GO LOWER ON THIS STUFF I NEED GONE ALSO GOT A WHOLE ANOTHER EG PARTS HATCH CX
Old Mar 24, 2011 | 07:57 PM
nobodyphil's Avatar
i need a 95 integra front bumper, and want all red taillights. got any?
Old Apr 5, 2011 | 08:34 PM
bump
Old Apr 5, 2011 | 08:35 PM
bbb
Old Apr 26, 2011 | 10:10 PM
Katman's Avatar
pm'd for P0B/F22B ecu.
Old Apr 28, 2011 | 09:16 PM
PM'D Back
Old May 31, 2011 | 08:53 AM
90ZCREX's Avatar
Will you ship the 88-91 door panels? If so can you send me a pic?
Old May 31, 2011 | 05:01 PM
Sold,BUMP
Old Jun 11, 2011 | 10:52 PM
rex89sir2's Avatar
i need a post mount for for my motor mount on the driver side got one??
rex89sir2's Avatar
its a obd0 crx
Old Sep 3, 2011 | 12:02 AM
micronoob's Avatar
Im interested in the skunk 2 coilover'swill it fit a 95 integra ? And would you ship them?
Boosted_eg19
May 7, 2009 06:22 PM
