h22 swap 96 accord axle types?
Old Feb 28, 2011 | 04:27 PM
accordmatt's Avatar
Default h22 swap 96 accord axle types?
ok l did a h22 swap into my 96 accord. l got the halfshaft n axle from junkyard off 96 accord. well the boot cracked and leaking so lm just gonna replace axle. but ive heard alot of dif things. prelude axle is beefer and stronger and accord ones will fit also. also heard u gotta use accord inner and prelude outer and blah blah. which type of axle should l use?prelude or accord? and do l have to use inner of one and outer of another or what?
Old Feb 28, 2011 | 05:11 PM
accordmatt's Avatar
Default Re: h22 swap 96 accord axle types?
???anyone???
Old Mar 1, 2011 | 04:21 AM
TOP END MS's Avatar
The Prelude set-up is said to be better. You need either both Prelude shaft and axels or both Accord. The difference is one uses an intermediate shaft with a male end and the other has a female.
Old Mar 1, 2011 | 04:56 AM
TheMuffinMan's Avatar
He knows where you live!
Correct, you can mix/match axles as well, provided the intermediate shaft and driver's axle are the same.
Accord driver's axle, Accord intermediate shaft, Prelude passenger axle works
Old Mar 1, 2011 | 05:35 AM
GhostAccord's Avatar
Or until you are putting 400-600 hp to the ground you could stick with the Accord axles.
Old Mar 1, 2011 | 06:53 AM
accord_raffi's Avatar
Old Mar 1, 2011 | 01:29 PM
accordmatt's Avatar
ok thanks guys ill probaally go with accord axle for now
Old Mar 1, 2011 | 01:46 PM
Console82's Avatar
I apologize if this message has been posted in the wrong area, I am severely new to Forums and have no clue where or how to post...But My question is simple to anyone local to the LA area, where/how do I find a engine for my 91 honda accord lx? I want to replace it with the same type, whatever it came with stock I think its a F22A1...or replace it with whatever is going to keep me in a decent budget and still Legal.
Old Mar 1, 2011 | 03:43 PM
accordmatt's Avatar
yea u need to create new thread read forum rules and follow them 1st
Old Mar 1, 2011 | 03:45 PM
accordmatt's Avatar
https://honda-tech.com/forums/honda-accord-1990-2002-2/accord-forum-rules-read-follow-1664182/ READ 1st as it states
1JDMCB7
Nov 9, 2010 12:15 PM
jdmlude_dude
May 26, 2006 06:06 AM
Subwarrior
Apr 1, 2005 05:07 AM
LSvtech
Jan 2, 2005 12:53 PM
4doorH22
Apr 15, 2002 10:18 PM
