eg windshield wipers
parts call for a 22'' driver side and 18'' passenger side. one wiper goes all the way to the roof of the car on the windshield (the driver side) and the other is like 4'' below the roof on the windshield. any1 have a better suggestion than a 4'' difference. seems a bit odd its that large of a difference.
That's the exact same size I have on my 92 EH3 and there is no issue. I'm going to ask because I've seen it before, have you measured the blades and made sure they are that size? Meaning I have run across wrong size blades in the packaging.
I run 19" and 21" on my eg coupe. Is you wiper arm bent? My buddies hatch had a similar issue and the wiper arm was bent causing the wipe pattern to move up.
i didnt, no. ill check everything when i take them out, prob put them on today and check them out. it just looks retarded when there is dirt or grime on the windshield from after it rains and you can see where the wipers dont hit and there is a huuuuge gap from one to the other
willy.wonka
Nov 4, 2003 11:12 PM
